Old 02-21-2015, 07:12 PM   #11
geotex1's Avatar
Originally Posted by Jerry427 View Post
How hard is the 50 amp progressive hardwired to install?
It's quite easy. You can get the instructions here:
http://www.progressiveindustries.net/manuals/HW50C.pdf
If you are putting the 50A on a 30A, you just add a jumper between L1 and L3 terminals.
geotex1 is offline   Reply With Quote
Old 02-21-2015, 09:45 PM   #12
Jerry427's Avatar
Thank you for the link very good instructions
Jerry427 is offline   Reply With Quote
Old 02-21-2015, 10:19 PM   #13
trbomax's Avatar
I have a progressive industrys 50 a portible,are these ok? its a mod ssp-50.
trbomax is offline   Reply With Quote
Old 02-22-2015, 09:37 AM   #14
davel1971's Avatar
that model is just a surge protector. Does not offer protection from all the other things that often go wrong.
David & Lynn
Old 02-23-2015, 02:17 PM   #15
Blog: RVroadtripper.com
hbillsmith's Avatar
I noticed in the manual it says never plug the EMS into an inverter. If its hardwired, how do you deal with using your portable inverter/generator? With the portable units, I just leave the EMS off the shore line.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 02-23-2015, 03:43 PM   #16
trbomax's Avatar
It does surge,open nuetral,open gnd,polarity. What else is there?
Old 02-23-2015, 03:52 PM   #17
ferguson65's Avatar
I just grabbed this link from the surge protectors thread. Its a pretty good comparison of what each unit will do for you.
RV Surge Protector Comparison
I'm in the market for one, leaning toward the HW30. But the inverter thing is interesting. May have to call Progressive on that.
2013 F350 dually
2015 Palomino Puma 351THSS Premier Edition
2015 Nights camped 15
2016 Nights camped 5
ferguson65 is offline   Reply With Quote
Old 02-23-2015, 03:59 PM   #18
If you can, you want to get the EMS-PT50 its portable and will cover you for almost everything and is warrantied for life.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 02-23-2015, 07:08 PM   #19
davel1971's Avatar
high or low voltage is very common and very dangerous to anything electronic. Low voltage happens in summer when everyones AC is blasting
David & Lynn
Old 02-24-2015, 11:18 AM   #20
ryand's Avatar
That was my concern and why I went with a portable unit so I can select when to use it.
2011 Coachmen Catalina 28DDS
2015 Ram Bighorn 2500 6.4L
http://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
surge guards
