Old 09-08-2014, 08:37 PM   #1
Outdoor propane stove to camper
I am trying to run my 3 burner outdoor stove off my camper propane. How can I get this to work? Do I need to remove the regulator that comes on the stove and how do I connect it to the quick connections on my camper. The stove has the fitting to connect to a tank.
This is what I have:
Academy - Camp Chef Tahoe 3-Burner Stove
10 Chevy Silverado 3500 CrewCab
6.6L Duramax with EFI Live Tuner with 5 levels
560hp 958 Max torque 3:73 gears
2015 Crusader 351REQ
cajun225 is offline   Reply With Quote
Old 09-08-2014, 08:48 PM   #2
Forbes's Avatar
I added a quick connect "T" connection just under my tanks where the line comes down and goes back under the RV. Change the hose on the grill to a quick connect line with regulator. I got everything at Lowes in the grill section for around $25.00.
Forbes is offline   Reply With Quote
Old 09-08-2014, 08:57 PM   #3
So I need to keep the regulator on my stove? I have a quick connection on the rear of my camper already that runs through my camper regulator.
Old 09-08-2014, 09:02 PM   #4
Campin Cajun's Avatar
You can get some hoses made or order some online that will hook up to the connection you have in the rear of your camper.
I have the double burner like yours and I hook to my RVs propane tank. I have a line running to the PS in the middle.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 09-09-2014, 05:18 AM   #5
I have the 2 burner like that I just got a male quick connect fitting from a rv dealer and a double female flare and a male flare to pipe thread fittings from the hardware store and put on the stove where the gas line would connect and just use my quick connect hose for the camperClick image for larger version
Name:	ImageUploadedByForest River Forums1410257837.945196.jpg
Ksanch is offline   Reply With Quote
camper, door, propane
