Old 06-16-2011, 02:01 PM   #1
Send a message via Skype™ to toshu
Outdoor recliners
We have been thinking about buying a pair of zero gravity outdoor recliners for use with our TT. The ones in the local stores look cheap, like they will rust the first time we leave them outside.
I also checked on Amazon, and a lot of units had bad reviews from a quality perspective.
I am wondering what brands/models fellow campers have and how happy they are with them??
Also, I am 6'2', 190#, so i need an XL model that will be comfortable for my tall body, and not all brands make them.
Finally, between the different options of > Mesh, Material, or Padded, which one makes the most sense in real use??
-2009 Ford F-150, SuperCab w 8 ft bed
5.4L Screw, 3.73 rear, 8200 GVWR
-2011 Rockwood 2604, 2x6V Interstate U2200 batteries,Yamaha 2400 genny
-2011-23 nights
toshu is offline   Reply With Quote
Old 06-16-2011, 03:13 PM   #2
camper_Lucy's Avatar
We have a set from Cabelas, after checking around and sitting in a few these seem to be the best, I am 6' 210lbs and also got an XL version and a regular one. After having them I can say the regular size works fine.
Now the bad side, after three seasons of using these only while camping and not leaving out in the rain ( always moved to under the awning or under the TT during rain) the rivet on the front of the handles (where the locks are) rusted through on both of them, not a big deal to fix I drilled out the rivet and put in a bolt, IMO that is how they should have built them, but beware from speaking with others that is where they all seem to fail,some in a year or less.
2011 GMC 3500HD 4x4 Crew DRW Duramax
Pullrite 20.5K
2012 Sierra 365SAQ
2006 Police Roadking FLHPi
camper_Lucy is offline   Reply With Quote
Old 06-16-2011, 03:25 PM   #3
10Isola
I too have two from cabella's. I'm 6' 235 and have found the larger seats are more comfortable. We have had them for 3 years and they have held up nicely. The finish on the wood handles is starting to go, but not a big deal. I'm finding myself packing these chairs less and less because I do find them to be bulky, heavy and space killers. Hope this helps.
10Isola is offline   Reply With Quote
Old 06-16-2011, 03:39 PM   #4
On the Cabalas site it appears that the XL size is the same height but just wider......is this correct???
-2011-23 nights
Old 06-16-2011, 04:38 PM   #5
leencharlotte's Avatar
I am not sure of the brand I got but I purchased them at the RV show from www.billplemmonsrv.com in NC. They are rated for 350#, which is higher then most. We got the standard as the XL's were only wide not longer. Ours are also padded, which may be slightly warmer but you could easily fall asleep in them
Suggestions:
Get one that can lock in reclined position
The bottom leg bar bothers my Achilles tendon, solved by putting a piece of swim tube over it
Not as much a suggestion as an annoyance, most have no place to put your beer as they lack drink holders
2011 F-350 SRW Lariat FX4
2014 Sandpiper 365SAQB
leencharlotte is offline   Reply With Quote
Old 06-16-2011, 04:43 PM   #6
Suggestions:
Found a link Faulkner is the manufacturer, they have a few in regular and XL
http://www.amazonrv.com/ProductDetai...ID=76&MRID=777
Old 06-16-2011, 04:49 PM   #7
Faulkner has terrible reviews lately on Amazon.....
-2011-23 nights
Old 06-16-2011, 05:13 PM   #8
No problems with mine at this point. Used on 4 trips so far. It has even held my 6'7" 325# neighbor. I can say they are slightly heavy
Old 06-16-2011, 07:09 PM   #9
Ehlendt's Avatar
Send a message via Skype™ to Ehlendt
I purchased this model from Gander Mountain. Gander Mountain® > Gander Mountain Zero Gravity Aluminum Lounger - Camping > Outdoor Furniture > Chairs :
Had it for a year now, with no isues to report. Put it under the awning at night. I'm 6' 4" and 255 lbs and this thing is very comfortable for my frame. It has a removable drink holder/tray which is nice. Love it!!!!!
John & Johnna
2005 Tahoe Z71
2010 Salem 26TBUD
Reese WD Hitch
"Get busy living.....or get busy dying."
Ehlendt is offline   Reply With Quote
Old 06-16-2011, 08:11 PM   #10
Why don't you rub it in!!!!
