I have a 14 forester 2701 ds with the outside TV. I would like to know how to remove it as I will never use it. I removed the couch and had access to the dvd player but could not see how to get to the TV without removing the wall.
Is there a trick? Thanks
The TV is removed from the outside, just push up on the TV then tilt out at the bottom. It is on a hang on bracket.It may be tight so don't be afraid to push up
I thought I would never use mine also, but the first time I sat outside with a beer watching TV and turned around and saw seven people standing behind me in awe that there was a TV outside I was hooked.
Wow do I feel stupid, it took 30 seconds to remove it. The reason I removed the couch is the tech at the dealer told me it had to be done. I think he should read this forum. Thanks again.
