Old 10-30-2014, 08:23 PM   #1
Outside TV removal
I have a 14 forester 2701 ds with the outside TV. I would like to know how to remove it as I will never use it. I removed the couch and had access to the dvd player but could not see how to get to the TV without removing the wall.
Is there a trick? Thanks
bouser is offline   Reply With Quote
Old 10-30-2014, 08:40 PM   #2
The TV is removed from the outside, just push up on the TV then tilt out at the bottom. It is on a hang on bracket.It may be tight so don't be afraid to push up
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 10-30-2014, 08:53 PM   #3
Thank you . I see you have the same setup with your model.
Old 10-30-2014, 09:20 PM   #4
I thought I would never use mine also, but the first time I sat outside with a beer watching TV and turned around and saw seven people standing behind me in awe that there was a TV outside I was hooked.
2014 Forester 3051s
2012 Sonic toad
Old 10-31-2014, 10:36 AM   #5
Wow do I feel stupid, it took 30 seconds to remove it. The reason I removed the couch is the tech at the dealer told me it had to be done. I think he should read this forum. Thanks again.
