Old 08-03-2015, 10:59 AM   #1
Mrs Evans's Avatar
Question Overall Cleaner for the TT
These days there seems to be a different product for every little thing so... by any chance is there ONE product that can be used to effectively clean my roof (TPO type), the trailer itself (aluminum) and the awning?
Michelle Evans
Katy, TX
2011 Carriage Cabo 341
2014 Wildwood 231RBXL - Traded Her In
2016 Days Camped = 5; Reserved = 14 so far
2015 Days Camped = 24 / 2014 Days Camped = 23
Mrs Evans is offline   Reply With Quote
Old 08-03-2015, 11:35 AM   #2
I use (Awesome) on everything you just ask about Plus the Exterior Walls! Have only been using it since the unit was New (2010) and the decals and Finish look New! I apply (303) on the Decals after cleaning! Youroo!!
Old 08-03-2015, 11:41 AM   #3
Dutchtexan
Dutchtexan's Avatar
TT Cleaners
Same as above, AWESOME cleaner and 303, Awesome cleaner can be purchased at your local Dollar Tree store 303 online.
TT: 2014 Forest River 27VRL Super-V
V-nose TT w/Rear Living area, 2 slides, Equal-I-zer 4 point hitch #10000
TV: 2011 Chevy Silverado Z71 Extended Cab AirLift 1000 w/WirelessAIR
Dutchtexan is offline   Reply With Quote
Old 08-03-2015, 11:43 AM   #4
Mrs Evans's Avatar
That sounds Awesome! I was hoping that would work b/c I had already bought a couple of bottles of that stuff to clean the awning with and then started worrying about whether it would work for everything else that needs to be cleaned on the exterior. As for the 303, I'm going to guess you mean this stuff here?
303 Aerospace Protectant
Thanks again!
Michelle Evans
Katy, TX
Old 08-03-2015, 11:49 AM   #5
Yep on the (303 pro)! and if you rolled a bug or leaf in your Awning and Stained it use a (Mr Clean Eraser with a little Awesome on it)! Youroo!!
Old 08-03-2015, 11:52 AM   #6
Dutchtexan
Dutchtexan's Avatar
Yes, the 303 Aerospace Protectant is GREAT for sealing your roof and is very similar to "Armor All" protectant but much, much, better. "Caution" Very slippery.
Old 08-03-2015, 12:13 PM   #7
do you get awesome at the dollar store?
wire1946 is offline   Reply With Quote
Old 08-03-2015, 12:21 PM   #8
Mrs Evans's Avatar
I 'totally' should have, lol! Because they sell it at 'Dollar Tree' for $1 a bottle, but alas I didn't But I will the next time I need it
Michelle Evans
Katy, TX
Old 08-03-2015, 12:53 PM   #9
Be careful using Awesome full strength on tough black streaks as I have made some paint get transparent from using it full strength. It was on Metal siding that was in bad shape for long time. If rag turns white on white paint it is removing paint. Good stuff though. I have found using good cleaner wax on tough black streaks works much better. It will rub through the old paint too. Best thing I learned was to not let them get in bad shape. Now if I could just practice what I preach.
Ke5rbd is offline   Reply With Quote
Old 08-03-2015, 01:04 PM   #10
mjones12's Avatar
If you wash a few times between waxings, does the Awesome shorten the life of the wax any more than regular soap and water? Thanks
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 08-03-2015, 02:11 PM   #11
rsdata's Avatar
liquid Spic and Span diluted in water
$1 at the Dollar store or Walmart...
been around forever and works on anything
use it on my roof and TT sides
2014 Shamrock 183
Old 08-03-2015, 03:58 PM   #12
diesel dog
I use totally awesome 5 to 1 ratio dont use straight will damage paint.use plenty of water to wash off. I use a product called lucas slick mist gives good shine & is easy to use will brighten decals. Bought used trailer w/fiberglass gel coat that was dull used turtle wax polishing compound then used lucas slick mist wife said that it really brighten the trailer up.Big thing is keep trailer washed & waxed.
2011 lacrosse 301rls
pulled 2007 chev duramax
savoy is offline   Reply With Quote
Old 08-03-2015, 06:00 PM   #13
I use Murphy's Oil Soap. Works great.
Stovebolt is offline   Reply With Quote
Old 08-03-2015, 06:53 PM   #14
I've been using Simple Green diluted to wash everything on the TT for the past ten years. I use it a little stronger on tires and wheels and stubborn stains and it does not harm the finish or wax if properly diluted. And, it is bio-degradable.
magpi26 is offline   Reply With Quote
Old 08-03-2015, 07:58 PM   #15
I use a product called Bleche White. You can get it from any automotive store, or even from Wal Mart in the automotive section.
MOODMAN is offline   Reply With Quote
Old 08-03-2015, 08:06 PM   #16
at the rv dealership I work at awnings and tt's get KORKAY - great stuff- can use diluted or straight for tough spots
riverrat958 is offline   Reply With Quote
