03-18-2015, 10:58 AM
Packing up at camp site
So there are a lot of threads, youtube videos, etc detailing how to set up your RV when you get to a camp site.
As a brand new Surveyor Sport owner, my question is, what steps do you take when leaving the site. At first, I would think you just do your setup steps in reverse, but I imagine that it can be a little more nuanced.
What do you do when you disconnect city water, for example? Do you turn on all the faucets and drain the lines? Do you empty your hot water tank at the campground? What is your typical process?
Thank you!
03-18-2015, 11:20 AM
We pretty much do go in reverse
It also depends on your rig and what "extras" you have installed
Find what works for you and turn it into a checklist (do this for your setup routine as well)
Keep the checklist handy (we keep ours in a checklist app on our iPhones)
Use the checklist every time - even when you think you have it down pat!
Can't count the number of times I have flagged down a camper leaving the CG with their batwing up or caps dangling from the sewer
Oh and YES there's an app for that (at least on iPhone) called RV Checklists - think it is $1.99 and has a slew of pre-loaded checklists not just arrive/depart, but PDI, Winterization, trip/Maintenance and the ability to create your own lists. We use that feature to keep track of supplies we store inside our rig and develop packing checklists for RV trips
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
03-18-2015, 11:30 AM
In time everyone develops their own take-down system or routine. In an attempt to not forget anything we USUALLY try to follow our set-up routine in reverse I.e., CATV, black, grey, galley sewer hoses, water, stabilizing jacks, hitch-up, electric, locks, wheel chocks. Then DW does a walk around to see if we (that is, I) missed.
2015 Silverado gas ext cab 2500
2014 Flagstaff 8528IKWS
03-18-2015, 11:36 AM
The only time we drain the trailer lines is when we winterize. A "Y" fitting on you hose at the CG bib is great to relieve pressure when draining your hose.
03-18-2015, 11:47 AM
Ah, the beauty of a TH,just disconect and pick up everything and throw it in the back.Deal with it when you get home,maybe.
03-18-2015, 11:56 AM
Thank you!
I think the best advice is to get into some good basic routine habits. Use the checklist to reinforce good habits but good habits make it simple and easy to both set up and tear down. Here are some general thoughts when camping with hook-ups.
We start with a good policing up of the camp area. Once all the camp items are stored away, garbage out etc we thoroughly dump/clean our black water tank and flush the grey. Again disconnect and store all the hoses etc. We drain the fresh tank down to about 10 gal. but don't drain the lines or h/w tank for traveling. At that point we store all the inside items, lower/check the antenna, check the water pump and water heater are off. Bring in the awning and slide and check all lights are off. We do a thorough walk around inside and out to be sure all is ready to hitch up. We disconnect the power as a last item, secure all doors and then go through the hitch up process. Whole thing is about 20 minutes. We find ourselves camping w/o hook-ups as often as with, so obviously some things change with regard to black water dumping etc but you get the point. Oh, and don't forget to pick up your gloves you had on and left on the picnic table
FR Wildwood 22 RKS
2007 1/2 Dodge 2500, Cummins 6.7
Retirement training completed
Currently enjoying second childhood
03-18-2015, 12:08 PM
The best thing we have done is that BOTH of us do a final walk around and I get on the picknick table and look on the roof. Then, after we do the dump, we do one final check for stairs, etc.
03-18-2015, 12:31 PM
Speaking of raised Batwings...this is our solution.
A souvenir from my Air Force Days...we hang this on the BatWing crank when we raise the mast at camp & remove if from the crank when the BatWing is down
We have a "bug out" checklist so we don't forget anything.
Basically, Nana is in charge of the inside (packing up, cleaning, storage, shutting windows and blinds) while I'm the outside guy. (Getting on roof for cleaning off the junk and checking the slideout before it goes in, sewage, water, power, truck hitch, etc.)
If you have a TT, I can share my bug out checklist with you.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
03-18-2015, 12:42 PM
Do a checklist ahead of time and edit it to your liking after a trip. I like to do electric last so I have shore power for he slide, stabilizers, and fridge. I keep water close to last for washing up.
I do outside, she does inside, we each help out if the other gets done first.
We pack dirty laundry after doing all the cleaning in case we need a t-shirt to protect breakables.
(Absolute last step on the checklist is read the checklist again, by the way.)
2011 PrimeTime Tracer 2600rls
03-18-2015, 01:32 PM
X2 on the final check! It's amazing what you can forget to do if your in a hurry or distracted.
2015 Rockwood Roo 23IKSS
2015 GMC Sierra 1500
03-19-2015, 12:55 PM
I found my Bug Out Checklist. (I printed it and laminated it and just use a erasable pen on it.)
Let's see if it can paste here:
RV Bug-Out Checklist (After Camping)
Clean campsite/get trash ready
Check roof for objects (esp over slide out)
Hitch reconnected
Check truck (tires, oil) wash mirrors/windshield - empty trash from truck
Chocks removed and stowed
Awning retracted
Wheels torqued
Stow folding chairs and all outside items
Shut off all gas pilot lights
Final sweep-out of floors
Furnace and A/C off
Hitch locked and secured
Levelers up
Lights and brakes checked
Lower TV antenna
Prepare refrigerator for traveling
Stow recliners/clamp down – stow lampstand
Tow Mirrors/Windshield Cleaned
Stow TV’s, ensure clamped.
Secure all loose items
Secure all windows and ceiling vents
Cabinets closed and locked
Stow shower and bathroom supplies
Shower/Fridge/Bedroom doors secured
Turn off propane
Water bottle for truck (pets drink)
Water heater off/110v switched off
Water pump off
Empty and stow trashcans
Prep truck (pillows/drinks/sunglasses etc)
Retract slide
All lights and fans off
Final bathroom call!!
Dump lone gray, then black/gray then clean black
All hoses stowed, caps on
Electric disconnected and cords stowed
Clean hands and final inside walk-around check
Stow entry steps
Final outside walk-around check, lock outside doors and stow door handles to the left
Rick & Karen
Monument, Colorado
03-19-2015, 05:14 PM
Packing It Up
Everyone has spoke of getting the camper ready for travel which is great, but I always check the fluids in our tow vehicle and remove the trash out of it before we leave. If I can, I clean the windshield, rear window and check air pressures in the tires of both it and the trailer. I carry a 3 gal. air compressor for this, which has been one of the best investments we've made to take with us.
03-19-2015, 05:23 PM
Left Coast
Wow......Sarge Do you start early?
03-19-2015, 05:46 PM
IGOST Trip Planner is an excellent app for smart phones. You can create your own folders (medicine, electronics, camp setup, fishing) than you can add under each what you need to check. You just check or uncheck it. I use this every time and has worked great.
Bruce & Nancy Richardson
Lexington GTS 300 S/S
Chevy Avalanche
Jeep Wrangler
Honda Goldwing
03-19-2015, 05:57 PM
Canadian Member
I always use the RV Checklist app on my iPad for both arrival and departure. I've modified the checklists to suit us and our TT. We tend to do half the checklist the night before we leave which makes for a faster getaway in the morning particular if we have a long day of driving ahead.
03-19-2015, 06:08 PM
As part of the routine, everything has a spot and it always goes back to the spot. We do basically the same as already reported. Awning and electricty is last. Never dump the hot water tank, water will burn you as it is upwards of 140 degrees or so so not a safe practise. That can always be done in the driveway during winterization. Develop a flow and timing to get it done, nothing worse than the incoming camper sitting there waiting.
Kevin
03-19-2015, 07:49 PM
We have the same thing on our crank too. It works to help the old grey cells!
03-19-2015, 08:05 PM
Similar trick, but hang the truck keys on the bat wing crank. You can't screw that up (well, it's possible but difficult).
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
03-19-2015, 08:07 PM
Would make it difficult to go get groceries.
