Old 01-11-2015, 10:16 PM   #11
Oklahoma Proud
MillerTime's Avatar
Paint gets really slick if any moisture gets on it, unless you can add texture to it somehow. If the cement is outside, you might take that into consideration, maybe ?
Old 01-11-2015, 10:35 PM   #12
Ret E-9 Anchor-clanker
donanddona's Avatar
I have heard of adding sand to the paint can for texture.. I just can't remember the type of sand.
donanddona is offline   Reply With Quote
Old 01-12-2015, 04:28 AM   #13
Ford Idaho's Avatar
https://www.google.com/#q=non+slip+paint+for+concrete
Bit more money but you just apply it.
Old 01-13-2015, 07:01 AM   #14
realebill's Avatar
I use a product that I purchased from home depot. It is made by Behr. Solid color concrete stain. I used it on my preformed concrete patio blocks after 3 years still looks great.
2008 rockwood signature ultra lite 8315SS[SIGPIC]
realebill is offline   Reply With Quote
Old 01-13-2015, 07:16 AM   #15
jtstromsburg's Avatar
I am a believer in concrete stain when outside. Not sure if an epoxy is OK in warmer climates like Florida or not. The behr product seems to work pretty good. I have a good friend that has a gym size auditorium he rents out for wedding receptions and it's held up for two years now, with tables drug around etc. I think prep work is the most important part. I sanded and then acid etched the whole floor, then neutralized, prior to him applying the single part coating.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 01-13-2015, 07:21 AM   #16
Walmart sells gallon cans of cement paint, I used it on my front steps about 5 years ago, still looks perfect. It only comes in "battleship gray" (that I was able to find, which is fine because we wanted gray) and it has the texture already in it (some type of sand). You have to mix it good because of the texture, but because of that it is never slippery. It was like $9 a gallon (tho it could be alot more now, like everything else).
_________________________
2018 Rockwood Mini Lite 2504S
2018 Ford F150 Lariat Special Edition 3.5 Ecoboost
Semperfi24 is online now   Reply With Quote
