Old 01-07-2014, 09:18 AM   #1
passenger chair
What an I missing? There seems to not be enough room to turn the passenger seat around. The seat doesn't go forward any more. The back goes down.I have tried every which way.
328 2014 Georgetown
Jo, Elliott, Cloey & Zoey (Havanese sisters)
Georgetown 2014 328TS; 2010 Toyota Corolla
JoanneL is offline   Reply With Quote
Old 01-07-2014, 04:53 PM   #2
Sbryant's Avatar
I have a 360 and had to learn that procedure also. Make sure the back of the chair is straight up, not leaning back. Move the seat all the way to the back as far from the dash that it will go. Then I could turn the chair around. I will then move the chair back toward the dash and lean the back of the chair back so it is comfortable to sit in. It took me quite a few attempts before I was successful. Good luck.
Sbryant is offline   Reply With Quote
Old 01-07-2014, 05:48 PM   #3
Thanks but I can't find how the chair itself moved forward and back
Old 01-07-2014, 05:53 PM   #4
Sbryant's Avatar
Sorry. Under the front center of the chair is a bar - mine is to the right of the center. Push is from right to left and you can push the chair front to back. On the right side of the chair (below the chair) is another bar and eggnog you pill it forward, you can turn the chair. I fjnd that turning the chair to the center of the MH is easier than turning toward passenger window.
Old 01-07-2014, 05:54 PM   #5
Sbryant's Avatar
Oh and I had to literally get down on the floor to find the bars.
Old 01-09-2014, 09:41 AM   #6
This forum is great. My husband was able to find it and it is turned around not that I will sit on it but it's good to know!!
