Old 09-30-2013, 09:30 AM   #1
Dave_Monica's Avatar
Picked up a little special something last trip!
I noticed this while the camper's sitting in the driveway after our last trip. It's a pop rivet...I've pulled it out a little for the photo. The tire is still holding full pressure.
Dave
Old 09-30-2013, 11:18 AM   #2
tomjsas's Avatar
Nice...not what you want to see! I had a BMW X5 that picked up a stucco/siding nail in the sidewall. Of course that meant a tire replacement
Tom
2004 Fleetwood Providence 38U
currently not towing a toad
tomjsas is offline   Reply With Quote
Old 09-30-2013, 11:32 AM   #3
tanddc's Avatar
I picked up a pop-rivet of my very own over Labor day. I was lucky to make it back home and found the tire all the way down 2 days later. Then I learned how to change tires on my new TT!
tanddc is offline   Reply With Quote
Old 10-01-2013, 02:10 AM   #4
Norma in Maryland
What do you need to change the trailers tires if you have to. What jack?
Norma in Maryland
Flagstaff 2013 8528BHWS
crickenwood is offline   Reply With Quote
Old 10-01-2013, 02:35 AM   #5
Ford Idaho's Avatar
I have a one foot long 4x4 with each end cut to 45, loosen lugs pull good tire on block replace flat with spare.
Replace lugs pull off block tighten lugs put stuff away drive to tire shop.
or
Be sure to use the emergency brake during this process!
Old 10-01-2013, 06:29 AM   #6
Papi
Papicamper's Avatar
Tongue in cheek...
Dave-Monica: You've been very helpful to me in the past so I'll help you this time...
If you just leave the rivet in and add about 300 more you'll have a great snow tire. See...it was meant to be. Well, add 300 more or take 300 trips to the same place.
PapiCamper
We're Fulltime in the Cedar Creek
and it ain't goin' nowhere. On 7 years
now in same place.
Papicamper is offline   Reply With Quote
Old 10-01-2013, 02:18 PM   #7
Anacortesians
I'd be concerned about the possibility that it's an unused rivet and that the 4" nail that works to "Pop" it is inside the tire. Since you've got sidewall damage, I'd be surprised if any tire shop would risk repairing it.
Frank and Eileen
No longer RVers or FR owners
Old 10-01-2013, 05:22 PM   #8
BuckeyeChuck's Avatar
Ouch!
2012 F250 Super Duty
2013 Sabre 33CKTS
BuckeyeChuck is offline   Reply With Quote
Old 10-01-2013, 09:49 PM   #9
As it turns outs, the rivet is in the spare that I had just mounted before the last trip...had never been on the camper before.
I'm waiting for a set of Marathon LR D's to be delivered as these OEM Duro tires are 4 years old...changing a little earlier then I planned, but that's the way it goes.
Dave
Old 10-01-2013, 09:57 PM   #10
Taranwanderer's Avatar
I hate foreign body tire damage--dammit, they wear out quickly enough on their own...
I just replaced all 4 tires that my dealer put on "new" when I bought the trailer in October of '11 (not quite 2 years now.) I didn't really notice that the tires the dealer put on were ST225/75D15s. "D" is the right load range, but the "D" in the name apparently means the tire is a bias ply and not a radial. So I had them all replaced with ST225/75R15s, and I bumped up to load range "E." I figured with all the stuff DW has put into the camper, a higher load range can't hurt!
Good luck with the pop-rivet thingie.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20 (‘18)21 (‘19)23
2019 Honda CRV (camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 04-14-2014, 07:02 AM   #11
Had the same thing happen to my truck tire in almost the same location. If it would been about one inch closer to the center of the tread it could have been repaired. But nooooo. :-)
Sent from my Nexus 7 using Forest River Forums mobile app
2013 Sabre 33CKTS
Old 04-14-2014, 10:03 AM   #12
Gravity challenged
Bob_Loblaw's Avatar
It's amazing how often the sidewall area takes the hit. If I didn't know any better I'd swear rotating tires create a magnetic field along the sidewalls....
Jim & Susan
2017 Flagstaff 832OKBS - Days camped 2022: 35
2013 Silverado 2500HD LTZ Duramax
Try to learn something about everything and everything about something. - Thomas Henry Huxley
Bob_Loblaw is offline   Reply With Quote
