02-04-2016, 12:29 PM
Picking up our new 16 Gray Wolf Saturday the 6th
Scheduled for our PDI at 1 oh clock Saturday, we are traveling 3 hours to AA Coach in Toledo. So excited we can hardly sleep. We have been reading and researching the threads to get a good idea as to what to expect. I made sure my salesperson knew I did not want to come all the way and not bring her home due to service issues and she assured me all will go well and I will be taking her home.
I have PDI checklist ready and will be sure to ask a lot of questions.
This will be our first TT and there is so much to learn.
John.
02-04-2016, 12:38 PM
Georgia Rally Coordinator
Make to to take notes also. Lots to learn and remember. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
02-04-2016, 12:52 PM
Congrats on your new Gray Wolf. Take a video of stuff like hot water bypass procedure and other things that are hard to remember.
02-04-2016, 07:21 PM
Thanks for the kind words.
02-04-2016, 08:48 PM
Congratulations. Hope everything goes well. My walk through went well. But a couple things I forgot and some I was glad others advised me to do:
1. Test the electric for the hot water heater. I did not and the next day I remembered and it did not work. The had forgot to plug it in. Easy fix
2. Walk the roof. I did and found 2 spots with small holes that happened when the mounted my fan covers. Pointed them out and they fixed with some Dicor.
3. Test the surround sound. We did not and it was not hooked up right. Had to get on forum for help to figure it out.
4. Learn how to work slides without power. I did not and took a while when battery died unexpectedly as we were about to leave. Had to find all the parts and read the manual.
Steve
2016 Rockwood Windjammer 3029W
2013 F350 Lariat Longbed 6.2L
02-05-2016, 08:35 AM
I will be installing the WDH myself when I get there. Question, it say to mount brackets 30" back from the coupler on the frame. Will I have any issues with the propane tanks being in the way? Any modifications need to consider?
Thanks.
02-05-2016, 08:52 AM
Thanks.
No problem with mine, you didn't state which model trailer or hitch.
Don't worry about the mule, just load the Wagon!
2015 Grey Wolf 19RR (Wagon )
2014 F150 XLT ECO Boost max tow (mule)
02-05-2016, 10:43 AM
Congrats! Your PDI should include things that you might not think about. Make sure the RV is connected to Power and Water. Make sure the Freshwater tank is EMPTY and the trailer is connected to City Water. When you turn on the City Water, open the Low Point drain (under the TT) and see if water starts to come out. This will be a sign that the Water Pump is not properly blocking the Backflow of water in the freshwater tank when connected to City Water. A VERY common problem. Sometimes it's as simple as putting about 1/3 of a tank of water into the freshwater tank and running the water pump to clear out any debris. After running the pump and opening the faucets for a few minutes, repeat the first test by draining the low point valve until the fresh water tank is empty and then connecting to City Water again and seeing if water comes out of the low point. Sometimes it requires replacing the water pump (which the dealer should have on hand). You REALLY need to add this to your list! BOTH of our Brand New Forest River RVs (first was a 2016 Vibe 308BHS and second is our new Coachmen 360IBL Fifth Wheel) have this problem. Both required the water pump to be replaced.
Also, check BOTH the AC and Furnace. Run them both for about 10 minutes each. First, you are checking to see if they work properly. Second, you want to make sure there isn't anything creating a blockage in the ducting.
Next, look at all the trim pieces around cabinets. Often times the cabinet installers do some very rapid fire nailing and miss fire all sorts of nails. ALSO, do a Pull test on ceiling trim to make sure it is secured properly. This is an area that will really bug you when trim starts to fall off.
Also, unscrew both the Kitchen and Bathroom faucet strainers (the part that the water comes out of) and check for debris. It is very common that plastic shavings will accumulate and block water flow.
You should go on Amazon and buy a 10pack of Soft White LED bulbs IF your trailer doesn't already have them. Amazon search for: GRV t10 921 SMD Bulb Lamp High Bright Warm White DC 12V pack of 10 (yeah I know it's long, so copy and paste)
If you have incandescent bulbs, they product a TON of heat (so hot you can't touch the light fixtures after about 10 minutes). They completely counter the efficiency of your AC unit. Replacing them with LED bulbs will dramatically improve the ability for your AC to cool your unit when hot outside.
Get a good TPMS system for your trailer tires. Though the tires they are putting on a slightly better than they use to be, you will probably end up with 225/75/15 Constancy D rated radials. If you have a fast leak, it could cause some MAJOR damage to the trailer while driving.
A good TPMS system (EEztire on Amazon) will run you a few hundred dollars but will save you thousands if a blowout occurs.
Corpus Christi, Texas
TT: 2016 40' Chaparral 360IBL at 14000lbs
TV: 2016 F450 Platinum 6.7 CC LWB FX4, B&W Companion Hitch
02-05-2016, 10:49 AM
Thanks.
Just make sure that the Bars, when sitting on the trailer L brackets, sit has Parallel as possible to the trailer frame. Which hitch are you getting? If the dealer sold you the hitch, I guarantee you paid about $300 too much for it. If it's a Fastway E2 or Husky Sway Control/WDH it should have cost you under $300 total. If it's a Equal-I-zer 4 point hitch, it should have cost you around $550-600 total.
Not worth adding a lower cost (Fastway or Husky) hitch to financing if you are going to end up replacing it with a higher end hitch after a few months (which you are likely to do).......I made that mistake.
02-05-2016, 10:56 AM
John.
Let me assure you that yours sales person, no matter how nice and informative she was before the sale, doesn't really care about the condition of the unit. Her job is to turn units and let service deal with the issues. She probably will do a 2 minute walk through before you get there to make sure there isn't saw dust all over the place, and to turn on the lights and get it ready for viewing. More that likely she will even coverup a few issues because she doesn't want you to see them and expect them to get fixed right away....thus delaying the deal. Don't let them pull the whole "if you have any problems, we'll take care of it for you" line. That simply means a 3 hour trip back to the dealership and dropping it off for a week so they can fix something that shouldn't have been broken in the first place.
You are FAR likelier to get a problem resolved BEFORE signing the paperwork than after (so as to not prevent the deal from happening).
Have them fix as many problems as possible DURING the PDI as that is the best time to get things done. Take pictures of ANYTHING that is questionable and DO NOT sign the release form (the IOU paper the dealership is required to have you sign) UNTIL you are completed the entire PDI. They will pressure to you sign a blank form...yeah, don't fall for it. Otherwise they are under no obligation to complete any work.
02-05-2016, 04:19 PM
Congratulations on your Gray Wolf. We purchased our 27 RR in November from the same dealership. They were very informative and easy to deal with. The employee that gave me the PDI was very thorough. Looking forward to using it soon.
02-05-2016, 04:42 PM
Casino Camper
Congratulations. I have a little different take on the PDI than most.
I would concentrate on looking for damage and worry less about things that are covered under warranty. You will have a hard time proving that damage to your trailer such as scratches or dents on the outside, roof tears, carpet tears/separation, cabinet scratches and dings and bent stabilizers.
As inconvenient as it is to get things repaired under warranty it is much more of an issue to get the dealer to fix damage if it was not pointed out at delivery inspection. If a pump or microwave doesn't work they will fix it without question but good luck getting them to replace a scratched cabinet or siding.
You don't know how many people have handled the unit. There is the person who hauled it to the dealer, the yard dog driver who moved it around the lot, the service tech who installed the propane and batteries etc..... Any one of them could have bumped or scraped something and would probably never report it.
In the end, it is just a camper and it will be a used unit on Sunday. It is nice to have perfect things but if you do spot damage, it could be a way to get a bigger discount on the final price rather than waiting a month for repairs.
Happy Trails!
2016 Cherokee 264L (Rear Living)
2013 GMC Sierra Denali
02-05-2016, 04:58 PM
Nothings easybtonget fixed under warranty when you're 3 hours from the purchasing dealership.
The more handy of a man you are the better. Self fixes are the best fixes.
02-05-2016, 05:09 PM
Congrats. One word of caution. Do not let your excitement cloud your good judgement. If there are any issues that you are not comfortable fixing when you get it home, don't sign anything. Spring is a very busy time for RV dealers ( everyone wants their new units or the ones that have been in for service and storage). Once the dealer has your money, their motivation to move you up in that long line is very minimal. You are buying this to enjoy and that won't happen if it is sitting on the lot in May waiting warranty work.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
02-08-2016, 01:09 PM
Congratulations. We have the Grey Wolf 23BD and really like it. There are some things like wall seams looking really tacky, but all of the important stuff works great. We have a Curt WDH for pulling it. I have not pulled it, but my husband says it pulls very nicely. Good luck and enjoy.
Chuck & Denise + Pata, The Purple Princess Peanut, Ziggy the pole cat and Kazumba the parrot
2015 23 BD Gray Wolf
2008 Dodge Ram 2500 TX Edition 2015 - 7 nights, 2 trips, 2016 - 2 trip, 24 nights, 2017 1 trip, 3 nights 2018 1 trip, 93 nights
02-09-2016, 04:36 PM
I bought a Husky Centerline, after reading reviews, being made in America and a lifetime warranty I thought that was a pretty good hitch and I got a really good deal, not from the dealership. I will need to make a few adjustments to it but no issues getting her home.
02-09-2016, 04:49 PM
Update: Picked her up Saturday and everything went very well, better than I expected. Nothing at all that needed attention except a little sweeping up of metal shavings by the hot water enclosure on the outside. Inside was very clean. Shane who did our PDI was awesome, very through and patient did not rush and he was ours until we were satisfied and on our way.
Our sales person was a little different story, she did not even see us off met her on the way in and that was that. I told Shane that he should of gotten the commission. Not a horrible experience though we are very satisfied.
I just got to remember that there is a trailer behind me and it is long, almost took out a gas pump. My 11yo son saved us along with our prayers. "And a little one will lead you" Stop daddy! Looked back and oh so close.
Thanks for all the recommendations. Know more reading!
Do people name their RV?
02-10-2016, 06:39 AM
MCTroy
I like your last question. Yes, RVs and trailers can be named. We have called ours many things... Some not so nice when we are having trouble backing up or hooking up! Since our current TT is longer and bigger than any previous ones, we dubbed it The Beast. That has now morphed to Beastie, sounds a little nicer... Enjoy your new trailer .
MCTROY
2015 Windjammer 3029 Diamond Edition
Hemi powered by 2011 Ram, 5.7 gas crew cab
Ohio River Rats and two spoiled dogs
2018 Ram 2500
Ohio River Rat
