Old 02-18-2015, 03:18 PM   #31
trbomax's Avatar
I have two and a half gallons of NAPA pink,-50.It is currently frozen solid at +5 on my carport. I first noticed this a couple days ago in the am when it had been -12. Its been solid ever since.
trbomax is offline   Reply With Quote
Old 02-18-2015, 08:18 PM   #32
TURBS's Avatar
1 degree f
TURBS
Old 02-18-2015, 08:23 PM   #33
Haven't checked this year but I totally freaked last year when our pink stuff froze. Ours is rated -50. It got pretty cold here in MI last year (and this year). All was fine.
233S
2500 Chevy Express
Nights camped 2013-22
mom28 is offline   Reply With Quote
Old 02-19-2015, 10:35 AM   #34
rsscully's Avatar
I set a full gallon jug out last night. It is supposed to get into the negative digits tonight without wind chill. I'll try to post a pic in the morning of the results
rsscully is offline   Reply With Quote
Old 02-19-2015, 10:38 AM   #35
Flybob's Avatar
Set out some Peak -50 RV antifreeze in metal can ( max heat transfer) last night this am temp was 10 and no slush. Expecting "0" tonight so will post again tomorrow.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-19-2015, 10:57 AM   #36
In 1 of my Unheated buildingI just pour (Auto Windshield Solvent) in the sink traps and toilet,(99c per gal)! I have only done this for 30+ years,will post results if freezing breaks anything! Youroo!!
youroo is online now   Reply With Quote
Old 02-20-2015, 08:10 AM   #37
Flybob's Avatar
Put 4oz Peak -50F RV antifreeze in metal container out last night, This am temp was 1F and the pink stuff has a consistency of thick slush. Certainly would not burst water line, but would not go through pump ot spigot.
TST Tire Monitors
2 100W solar panels
Old 02-20-2015, 08:28 AM   #38
rsscully's Avatar
Checked this morning when I came home from work. Thermometer says it got down to 0.9° last night. The bottle is not even slushy. I think I will be ok as I blew the lines out in the RV before pumping the antifreeze through.
Old 02-20-2015, 08:36 AM   #39
You can't compare "exposed" pink stuff freeze status, when the container is subjected to moving air across the surface. That produces a "wind chill" factor, which rapidly lowers the temperature of the medium as the ambient temperature drops.
My observatoon; -50 degree burst protection, Peak brand, still in liquid state at -5 F in protected location.
This sure is sounding like a product stated quality issue. Otherwise, why would the same stated -50 burst rated pink stuff, have different states of consistancy (totally liquid vs slushy) when the temperatures are what is being observed.
Old 02-20-2015, 08:41 AM   #40
Just curious, have you noticed any distortion in the shape of the container. I'd be curious to know if expansion occured with the pink stuff freezing solid. Just sayin'
antifreeze
