Old 10-22-2015, 12:34 PM   #11
Pickin' & Campin'
My wife uses one of THESE cast iron pans in our oven. Works great!
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 10-22-2015, 12:38 PM   #12
Originally Posted by doc73 View Post
We use an air bake pan. No troubles with breaking, it's metal, been through two camper and all is well.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Do you use it to bake on or just set it in the oven to distribute heat when you bake in another pan?
zinger60 is offline   Reply With Quote
Old 10-22-2015, 01:42 PM   #13
Who Dares, Wins
doc73's Avatar
We set it over the bottom. Use just like the pizza stone. Then will use whatever to cook on
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 10-22-2015, 02:24 PM   #14
We bought an expensive pizza stone and the same thing happened. Returned it to the store and got refund. Bought a real cheap one - same results. We don't bother anymore as the oven in our fiver gives us pretty good heat distribution. If I buy another, it will be a big oven baked clay tile.
Marcel & Jenne
Kemptville, ON
2014 Rockwood 8282WS
2015 Ford F150 Eco-Boost
BusyRetirees is offline   Reply With Quote
Old 10-22-2015, 02:42 PM   #15
We use the broiler pan. Works great and have used it for many years
2014 Wildcat 282RKX
2014 GMC Duromax 4x4
retired2 is offline   Reply With Quote
Old 10-22-2015, 02:56 PM   #16
OntarioFireFighter's Avatar
Found a 14" square cast iron BBQ grill pan at the local Lowes - about 1/2" thick - weighs about what you'd expect - a lot.... I think it was about 15 bucks.
Works great to even out the heat in our oven; we make a point of baking something every trip out (cinnamon rolls for Sunday morning breakfast is almost a given now) - and never have a problem (I do still rotate whatever I'm baking 2-3 times during the cooking time, just to keep it even.
2014 Grey Wolf 28BH, behind a 2015 F350 Diesel Crew Cab
Nights Camped 2016: 44
Nights Booked 2017: 11
Nights Camped 2017: 6
OntarioFireFighter is offline   Reply With Quote
Old 10-22-2015, 03:41 PM   #17
Burn relief
I never new how to keep stuff from burning in these little gas ovens. (Two boats, three different trailers). We traded for a new Flagstaff in late summer and I decided to use the cast iron griddle in the oven instead of my pizza stone from the house. I have only used the oven once, but my biscuits did NOT burn. In addition, I plan on using the griddle grill pan on the BBQ as well! Double duty is always a plus!
SLP2GO
Slp2go is offline   Reply With Quote
Old 10-22-2015, 05:27 PM   #18
Haulin' Camp
KewlKamperz's Avatar
Wrap the broken stone with aluminum foil. It will keep the broken pieces together, easy to clean, and the foil/stone combination works wonders.
2012 26TBUD
2004 Suburban
3 Kids
2 Dogs
KewlKamperz is offline   Reply With Quote
Old 10-22-2015, 08:26 PM   #19
dvalley's Avatar
As a baker I can tell you the reasons that a pizza or baking stone will crack
1) Moisture - can be from being stored in a humid area, condensation, or the stone just getting wet at all. Pizza and baking stones are not meant to be washed and humidity and condensation are not their friend.
2) Heat- warm your stone slowly starting with a cold oven and when done, let it cool in the oven until cold
3) Disparity of temperature- Food should be room temperature and should be heated along with the stone if possible. Never ever put a frozen item on stone, such as a frozen pizza as it will guarantee cracking. Let other items warm to room temperature before putting them on your stone.
4) A crack or fault in the stone. Stones are notoriously easy to develop hairline cracks from bumping when handling and storing.
Hope this helps you all!
dvalley is offline   Reply With Quote
Old 10-24-2015, 11:08 PM   #20
SilhouettePenny's Avatar
We had the same cracking issue with store bought stones, then got a California Pizza Stone and no problems since. 14 inch square stone for the 14 & 1/2 inch oven. Order online
2017 F350 Dually 6.7 Diesel
2014 Silhouette 299 RKDS
Nights Camped 2017 - 63
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
