Old 10-28-2015, 03:34 PM   #21
Mr. Dan's Avatar
Originally Posted by KewlKamperz View Post
Wrap the broken stone with aluminum foil. It will keep the broken pieces together, easy to clean, and the foil/stone combination works wonders.
I bought a 12"X12" piece of unglazed ceramic at Home Depot for 57 USD. I wrapped it with several layers of aluminum foil BEFORE we used it in the oven. We placed it on the shelf above the burner and baked a pan of biscuits to perfection. We didn't have burnt bottoms as before... and, Yes, the tile broke with a pop during the experiment but the parts didn't separate because of the foil wrap.
SEARCH is your friend!
Nights Camped: 2013 = 49 / 2014 = 74 / 2015 = 74 / 2016 = 74 (booked = 11)
Old 10-28-2015, 03:48 PM   #22
KyDan's Avatar
We use an airbake cookie sheet and place biscuits and sweet rolls in a bright aluminium pan on that. We haven't burned any since. This works better than a pizza stone! We used a pizza stone for several years until we swapped to the airbake sheet and it's way better and lighter.
Dan & Rita D
2004 5.3L Silverado 1500 ext. cab 2WD
Blue Ox WD hitch, AirLift load levelers
2013-41, 2014-31, 2015-40, 2016-38
Old 10-30-2015, 12:46 PM   #23
Tried a slate tile from homedepot, sound like fireworks going off in there.
Hornnumb2 is offline   Reply With Quote
Old 10-30-2015, 02:09 PM   #24
Who Dares, Wins
doc73's Avatar
Slate may shatter. Very porous and will pop as the water bakes out. Used to make rocks explode by soaking them in water then outing by the fire.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Pat, Jen & Heather... Oh yeah and our trained attack trailer cat, Cinnamon
2015 ChevyHD D-Max
2014 Greywolf 26DBH
doc73 is offline   Reply With Quote
Old 10-30-2015, 08:08 PM   #25
Been using a California Stone pizza stone for about a year and a half.
I heated it slowly, something around 200 for 15 minutes and just started cranking it up slowly until I had the oven maxed out. Probably spent an hour and a half seasoning it. It's been great so far, wife used it last trip for pizza of all things 😎
The stone I bought was too large for the oven, I cut it down with a grinder set up with a diamond blade. Nice and tight fit now which limits the vibrations.
meck51 is offline   Reply With Quote
Old 10-30-2015, 08:15 PM   #26
Ours broke in half, second use but it still does the job. Just use it broken as it still does the job, broken or not....
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
dalford is online now   Reply With Quote
Old 10-30-2015, 08:36 PM   #27
We use (to very good effect) four unglazed, 6" ceramic tiles from Menards -- maybe a buck apiece IIRC. No cracking. I sometimes have to reposition them a bit after going down the road, to make sure the holes on the side of the pan they sit on are fully exposed.
Rich Phillips
richp is online now   Reply With Quote
Old 10-31-2015, 05:39 PM   #28
Our Pizza Stone lasted 2 years before it broke. We checked into a Steel Pizza Stone. We Love it!!! It will not break, just don't drop it on your foot. In the house we place it on the upper most shelf and crank the oven to 500 Degrees plus, 30-40 mins. for preheating. We place our Homemade Pizza in the oven and 7 mins. later we have the greatest pizza you will ever eat! It is as close as you will get to a Brick Oven Pizza. P.S. 1/4 Steel Plate will also work.
Maverick50 is offline   Reply With Quote
Old 10-31-2015, 05:58 PM   #29
NKARENG's Avatar
We use a 12 x 12 unglazed tile. Have use the same title for two years and it hasn't broke yet.
2016 Freedom Express 281rlds
2013 Flagstaff Micro Lite 25DS
2014 Dodge Ram 1500
Days Camped 2015 - 20
Days Camped 2016 - 12
NKARENG is offline   Reply With Quote
Old 11-02-2015, 06:51 AM   #30
jonrjen's Avatar
We use a different approach, a toaster oven. Works great, nothing to break, uses no LP in the process of heating, baking.
2013 Ford F350 FX4 4x4 PSD
2013 Wildcat 353LS
2015 Day/Nights Camped 5
2014 Day/Nights Camped 29
jonrjen is offline   Reply With Quote
