Old 04-07-2016, 09:49 PM   #11
gectisme's Avatar
Amyone try one of those Puma 12v air compressors? They are kinda on the big side and draw a lot of current but seems like a good price..
Here is a link to one on Ebay:
Puma 12 Volt 1 5 Gallon Oil Less Air Compressor Free Shipping Oiless 12V | eBay
2016 Windjammer 3006WK
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, (not really used, left over from our truck camper). Equalizer E4 1.4k/14k WD Hitch. TST 507 TPMS. Furrion FOS48TA Observation Camera. Garmin RV-760 GPS. Honda 2000i Genny, PI EMS-PT30C.
MISSION COMPLETED!
gectisme is offline   Reply With Quote
Old 04-07-2016, 10:02 PM   #12
CWSWine's Avatar
Originally Posted by davel1971 View Post
yes, a 110 volt compressor with tank will work better, but that means nothing along side the road. 12 volt works anywhere. Better slow fill than no fill.
Not a problem along side the road when you have a inverter that provides 120V. My 1000 watt inverter will power my residential fridge running for 18 hours it will power my 120V compress or few minutes.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 04-07-2016, 11:52 PM   #13
Fulltime family RVer
That definitely depends on the 12v one. My Viair doesn't take near that amount of time and I've gone from 115 to 125psi with it before. In fact, I'll be doing that here shortly...
I topped up my tire with the leak tonight - 108psi to 125psi in 3-4 minutes. My prior Porter Cable 3 gallon pancake compressor wouldn't push air into my tire up over 118 psi.
Old 04-08-2016, 05:20 AM   #14
World Wide Wanderer
wahoonc's Avatar
I use Viair, we have several of them that we use around the farm. If you don't have ready access to 120v it is the only way to go.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 04-08-2016, 05:28 AM   #15
davel1971's Avatar
I understand that, but most people don't have one, so that's not an option. Everyone has 12 volts all the time.
David & Lynn
Old 04-08-2016, 08:00 PM   #16
With generator 110 everywhere.
AbdRahim is offline   Reply With Quote
Old 04-08-2016, 08:02 PM   #17
Portable Air Compressor
Aaron
I have 2 I would like to get rid of. Though I guess I should keep one for the car.
Old 04-08-2016, 08:07 PM   #18
World Wide Wanderer
wahoonc's Avatar
My TT did not have a generator. The Viair and a plug kit saved me from a lot of grief more than once.
Aaron
Aaron & Rhonda
Old 04-08-2016, 08:19 PM   #19
Jumper cables would've made a good extension cord in a pinch, vice kinking your hose.
2011 Traverse LT, 3.6L, FWD
