Old 04-07-2016, 06:46 AM   #1
Portable Air Compressor
I am looking for a portable air compressor to carry in our 2016 Forester 3011 DS. I prefer one where you do not screw the fitting onto the tire valve and AIR RITE valves. Any feedback would be greatly appreciated on what others have for their RVs and how well the compressor you have works. Thank you
JerJ is offline   Reply With Quote
Old 04-07-2016, 06:54 AM   #2
"On the road again"
rjshiflet's Avatar
I carry a small "pancake" type compressor with a yellow coiled hose. It's served me well over the past four years - https://goo.gl/EWDZTB
Robert & Estha Shiflet
Georgetown XL 378TS
Jeep Gladiator Willys Tow Vehicle
rjshiflet is offline   Reply With Quote
Old 04-07-2016, 08:02 AM   #3
I did a video on what I have (VIAIR 300).
2021 Micro Lite 25FKBS
2021 Ford F-250 XLT CCSB 4wd w/ 6.2l and 6 sp. transmission, 3.73 locking axle
gmacklem is offline   Reply With Quote
Old 04-07-2016, 08:15 AM   #4
Always Learning
Another vote for the Viair. I have the 450P because I have 10 tires and my trailer tires are put up to 125psi.
Old 04-07-2016, 08:59 AM   #5
I see I can get this for $149 on amazon. Feeling pretty silly since I bought a small 110v air compressor for $100 while I was in florida and it's useless to me on the road.
I bought it to blow the water lines out on my trailer for when we left our stop at Valdosta GA on the way back. Well my camper shell lock froze up and I couldn't get to it, so that didn't happen. I just drained it and prayed.
2012 Windjammer 3001W
2016 Sunset Trail Super Lite 250RB-For Sale
2015.5 Chevrolet Silverado 2500HD LTZ crew cab Z71 4x4
KingFisher is offline   Reply With Quote
Old 04-07-2016, 10:51 AM   #6
CWSWine's Avatar
I had a 12 volt pump little smaller than the ones in the video and took about 5 minutes to raise the tire pressure 10 lbs. I purchase a small 110 volt compressor with two smaller storage tanks that works 10 times better then the 12 volt one. I normally fill my tires at home or at a camp site so the 110 with a 25 foot extension cord was the easiest option. If I need to use on the road I have a 1000 watt inverter that runs my fridge and I can plug into i and 110 when on the road and fill a tire if I need to.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 04-07-2016, 12:58 PM   #7
Always Learning
That definitely depends on the 12v one. My Viair doesn't take near that amount of time and I've gone from 115 to 125psi with it before. In fact, I'll be doing that here shortly...
Old 04-07-2016, 01:02 PM   #8
Kenny kustom's Avatar
X2!
The compressor in my jeep will run air tools..
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Kenny kustom is offline   Reply With Quote
Old 04-07-2016, 09:23 PM   #9
Had two 12 v ones. What a pain. Bought this one: http://www.amazon.com/PORTER-CABLE-C...air+compressor.
Makes life much easier. Fits nicely in rear cargo bay. Plug into 120 outlet on the side of the coach. Got a hose long enough to fill all of the tires and air bags.
AbdRahim is offline   Reply With Quote
Old 04-07-2016, 09:31 PM   #10
davel1971's Avatar
yes, a 110 volt compressor with tank will work better, but that means nothing along side the road. 12 volt works anywhere. Better slow fill than no fill.
David & Lynn
2014 Coachmen Chaparral Signature 327 RLKS
2016 Ford F350 Lariat CC Dually
davel1971 is offline   Reply With Quote
Old 04-07-2016, 09:49 PM   #11
gectisme's Avatar
Amyone try one of those Puma 12v air compressors? They are kinda on the big side and draw a lot of current but seems like a good price..
Here is a link to one on Ebay:
Puma 12 Volt 1 5 Gallon Oil Less Air Compressor Free Shipping Oiless 12V | eBay
2016 Windjammer 3006WK - Sold July 2018
2002 Lance Lite 835EC TC - Sold July 2015
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, Sold Mar 2019.
MISSION COMPLETED!
gectisme is offline   Reply With Quote
Old 04-07-2016, 10:02 PM   #12
CWSWine's Avatar
Not a problem along side the road when you have a inverter that provides 120V. My 1000 watt inverter will power my residential fridge running for 18 hours it will power my 120V compress or few minutes.
Old 04-07-2016, 11:52 PM   #13
Always Learning
I topped up my tire with the leak tonight - 108psi to 125psi in 3-4 minutes. My prior Porter Cable 3 gallon pancake compressor wouldn't push air into my tire up over 118 psi.
Old 04-08-2016, 05:20 AM   #14
World Wide Wanderer
wahoonc's Avatar
I use Viair, we have several of them that we use around the farm. If you don't have ready access to 120v it is the only way to go.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 04-08-2016, 05:28 AM   #15
davel1971's Avatar
I understand that, but most people don't have one, so that's not an option. Everyone has 12 volts all the time.
David & Lynn
Old 04-08-2016, 08:00 PM   #16
With generator 110 everywhere.
Old 04-08-2016, 08:02 PM   #17
Aaron
I have 2 I would like to get rid of. Though I guess I should keep one for the car.
Old 04-08-2016, 08:07 PM   #18
World Wide Wanderer
wahoonc's Avatar
My TT did not have a generator. The Viair and a plug kit saved me from a lot of grief more than once.
Aaron
Aaron & Rhonda
Old 04-08-2016, 08:19 PM   #19
Jumper cables would've made a good extension cord in a pinch, vice kinking your hose.
2011 Traverse LT, 3.6L, FWD
