Old 06-23-2013, 06:50 PM   #11
BombDoc's Avatar
Originally Posted by herk7769 View Post
We also have the 42 Gallon tank and made a mount out of perforated structural steel, aluminum plate and some stainless steel 4 inch square U bolts from Granger. I also upgraded the wheels for quieter towing behind the truck and easier pulling if close enough to walk.
Lou, how did you attach the structural steel to the camper?
John & April & "Scout"
2013 Sabre 32RCTS-6
Nights Camped 2013-(44) 2014-(59) 2015-(47)
2016-(32) 2017-(13) 2018-0
BombDoc is offline   Reply With Quote
Old 06-23-2013, 07:24 PM   #12
Herk7769's Avatar
It is not attached to the camper; just the bumper. By reversing the clamps and mounting the steel on the camper side of the bumper there is about an inch of space between the steel and the wall.
I made "bumpers" from white crutch tips and cut them an inch and a half long and mounted them to the steel with reversed bolts (washer inside the tip) and the lock washer and nut on the steel. Once everything is tight, those crutch tips are hard up against the wall and there is very little play.
I had to pry the structure away from the wall enough to place the crutch tips where they needed to go (loosening the bumper U-Bolts helped) then tightened everything up. The crutch tips are starting to show their age and I will need to replace them in a year or two (they are 3 years old now).
HAM CALLSIGN - KC3FFW
Old 06-23-2013, 07:27 PM   #13
BombDoc's Avatar
I got it! I thought from one of the pics, you had actually mounted the steel to the camper. Great mod and thanks for the explanation.
2013 Sabre 32RCTS-6
