Old 06-22-2013, 08:50 PM   #1
ryand's Avatar
Portable/Blue Boy
I am debating on purchasing a portable tote tank for use as we have rarely camp with full hookups and we are looking to start extending our trips up to a week without water or sewer next year. I have managed to solve the water issue with a few 6 gallon tanks but would like to have a solution to the waste. Looking at the Barker 42 Gallon model. I can store it under the Trailer when not in use and load it in the back of my truck but I really would like to make a removeable mount to store it behind the axles Under the trailer when traveling. Any one ever done this or seen it done? Anyone have any opnion on the models available? Seen Thetford and Barker as the main choices. Am I missing anything?
2011 Coachmen Catalina 28DDS
2015 Ram Bighorn 2500 6.4L
http://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
Old 06-22-2013, 09:09 PM   #2
dcheatwood's Avatar
I have a 30 gal and it weighs more than 270 lbs full. It was work loading it into the truck. Room 3 men. I hope you find a way to mount it. I'll be following your post for ideas. Good luck.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 06-22-2013, 09:15 PM   #3
ryand's Avatar
I would intend to tow it and only load/mount when empty.
Old 06-22-2013, 09:16 PM   #4
BombDoc's Avatar
Ryand,
I just purchase a Barker 22 Gallon tote along from a local RV Repair place here in my small town. Didn't want to drive 45 minutes to CW and the one I purchased was bigger than the 15 gallon one available for sale at our favorite SP camp ground store. We like our local SP a lot and have been out there often. None of their sites have full hook ups. We were out there last weekend for 3 nights and 4 days. I needed the ability to dump one of my gray tanks that holds the kitchen sink water. The 22 gallon Barker I purchase came with an attachment that allows me to hook the tank to my 2" ball on the back of my TV and drive to the dump station. Cost for the Barker was $159. We will be tailgating in the fall for college football and have reserved a spot in the fairgrounds. I will need it once the coldies start flowing and we will be at the spot from Friday night until mid day Sunday. I haven't used it yet, but know I will. I really like the ability to hook it to a friends golf cart or to the rear of my truck instead of hand pulling it 300 yards to dump. Hope this helps.
John & April & "Scout"
2013 Sabre 32RCTS-6
Nights Camped 2013-(44) 2014-(59) 2015-(47)
2016-(32) 2017-(13) 2018-0
BombDoc is offline   Reply With Quote
Old 06-22-2013, 10:46 PM   #5
dcheatwood's Avatar
Bombdoc. I have the barker 30g. The telescoping steel tow bar is a back saver on short runs. I think with better tires it could make a longer trip.
Old 06-23-2013, 09:00 AM   #6
ryand's Avatar
Would you recommend getting a tank large enough to hold a full dump of your rv tanks? Largest barker I have seen is 42 gallons or do you simply just never top off your tanks?
Old 06-23-2013, 09:10 AM   #7
BombDoc's Avatar
I personally wouldn't want one that large due to having a place to keep it while traveling and having to muscle around 42 gallons of waste water. My RCTS has 3 tanks, 2 gray and 1 black. Each are 42 gallons. I'd rather make a couple trips with a lighter tote than one trip with a really heavy one.
While out camping I have a tendency to watch others. The size I purchased seems to be the norm. Not too hard to store and light enough to handle.
2013 Sabre 32RCTS-6
Old 06-23-2013, 09:13 AM   #8
BombDoc's Avatar
I should add that it's just the DW and I most of the time. It takes us a little time to fill any of the tanks. If I had a camper full of little ones it would be much different I'm sure.
2013 Sabre 32RCTS-6
Old 06-23-2013, 09:40 AM   #9
Herk7769's Avatar
We also have the 42 Gallon tank and made a mount out of perforated structural steel, aluminum plate and some stainless steel 4 inch square U bolts from Granger. I also upgraded the wheels for quieter towing behind the truck and easier pulling if close enough to walk.
ID:	33826   Click image for larger version
ID:	33827   Click image for larger version
ID:	33828   Click image for larger version
ID:	33829   Click image for larger version
ID:	33831   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 06-23-2013, 02:22 PM   #10
dcheatwood's Avatar
Oh yeah. Towing is way better. But in this case, we had a 4 mile run, up hill to the dump station. Sticker on the side says no faster than walking speed. So that would have been a long haul. Lol. Mine has the thin plastic wheels on rear. No front wheels.
