Old 11-22-2015, 12:59 PM   #1
Night Stone's Avatar
Portable heaters
I been doing some research and did find others in this forum who use portable heaters in lieu of trailers furnace because of the propane usage for the coming winter. Temps as low as 25 this week at night. My rig is plugged into shore power(friend's house), so a 1500 watt heater is not recommended. I have checked out Herk's wall mount one, but a little pricey and will not work with my small trailer, lack of wall space. I have found 2 ideal candidates, under 1000 watts, I need only to heat small trailer, under 150 sq ft and was wondering if anyone uses them or something similar? Here are their links:
600-Watt Convection Electric Oil-Filled Radiant Portable Heater
Duraflame 600-Watt Convection Electric Oil-Filled Radiant Portable Heater-DFH-CH-11-T - The Home Depot
700 Watt Portable Electric Radiant Compact Heater
NewAir 400 Watts Portable Electric Convection Panel Flat Heater & Reviews | Wayfair
Thanks,
Dave
98 Chevy Silverado C3500 crewcab, 454 cu in & 2013 Salem Cruise-Lite 181BHXL
FRF and FROG member
Days camped in 2012 (3), 2013 (3), 2014 (6)
Days camped in 2015, 0 Days so far (0)
This Space for Rent
Night Stone is offline   Reply With Quote
Old 11-22-2015, 01:17 PM   #2
We use a small portable heater in our Windjammer. It is 1500 watts on high and 750 on low power. Usually use it on low so as to not over draw our circuits. We move it from the LR to the BR depending on where we are. It does a good job and we are happy with it.
Windjammin is offline   Reply With Quote
Old 11-22-2015, 06:59 PM   #3
Retired
MainelyUS's Avatar
portable heater PH
Name:	portable Heater.jpg
ID:	94823 Home Fusion Ceramic Heater Fan 1500W. During the evenings we place it on the stove top and it will keep the living area comfortable during the cribbage games...on those cold evenings/mornings we move it to the BR area which keeps both the bed & bath rooms quite comfortable. We close the hallway bed & bath room doors. If the night temps are going to be cool/cold we set the furnace to 60-62. First one up turns on the PH. Nothing like a warm bed/bath rm in the morning. This works for us.
I'm thinking of installing a dedicated circuit breaker and outlets in the Windjammer just for the PH. ANY THOUGHTS
Happy Trails and keep warm my friends
2017 Columbus 340RK
GMC Sierra 3500HD Z71 6.6L Duramax/Allison
MainelyUS is offline   Reply With Quote
Old 11-23-2015, 10:50 AM   #4
jeff64's Avatar
X2 on the low wattage setting. If the power cord is getting warm, your are drawing too much to chance when you have your eyes closed! I set mine to come on just before the furnace boots up and have changed out the slider t-stat for a digital Coleman-Mach
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 11-23-2015, 10:56 AM   #5
bpa098's Avatar
my question for cold camping, how do you protect the water lines and drains? or are you just sleeping in there and its winterized.
bpa098 is offline   Reply With Quote
Old 11-23-2015, 07:49 PM   #6
Retired
MainelyUS's Avatar
bpa098...check these two forums out...they might help you with your winter camping ?s
Forest River Forums > Hybrids and Expandables > Expandable and Hybrid RV Discussions > Roo | Shamrock
Reload this Page Winter Camping
Happy Trails
2017 Columbus 340RK
Old 12-04-2015, 08:54 PM   #7
Well we ended up with this unit, bought it at Wally World. Couldn't find the ones I wanted from the Walmart website, they said they have this heater in stock, soliel brand. Went to pick it but no soliel brand on shelf but found a suitable one and very good one if I might add.
It's made by Heat Wave, Blythe Tabletop Infrared Quartz Heater. 1400 watts, manual says it great using 15 amp circuit. Our TT is plugged on shore power, no tripped breakers and furnace hasn't come on since. It's an awesome heater and very quiet unit. I would recommend this for any one doing cold weather camping, as we are full timing in friends driveway. Here is a picture of it. We also paid the 3 dollars to have the 2yr extended warranty too from walmart, very good deal.
FRF and FROG member
This Space for Rent
heater
