Old 07-18-2015, 04:17 AM   #1
Portable second ac
Installed a 10000 btu portable ac in my bedroom to assist my 15000 btu roof mounted ac and the day I started using the portable, I had warmer temps in the kitchen/living room. It seemed to restrict the roof unit causing warmer temps. Any suggestions?
ZPROCK is offline   Reply With Quote
Old 07-18-2015, 05:26 AM   #2
Todouble's Avatar
Are you blowing the warm condenser air of the portable out a window or just letting it go inside the RV? If it's just blowing out in the rig it's probably adding more load to the original rooftop unit.
Todouble is offline   Reply With Quote
Old 07-18-2015, 06:28 AM   #3
Need more information to give you an answer
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 07-18-2015, 06:34 AM   #4
mud yapster's Avatar
Pics of 2nd A/C install would help
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 07-18-2015, 07:20 AM   #5
Georgia Frog Rally 2018
aceinspp's Avatar
More info on the AC unit would help. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 07-22-2015, 12:10 PM   #6
Well, look at it this way, your portable exhausts air from your camper. That air will be made up by air that will "bleed" in from the outside. Most likely that will be warm air. Your roof mounted unit does not exhaust anything ---- it recycles and cools as it does so. Your portable is most likely increasing the heat load for your roof A/C.
bruceatlam is offline   Reply With Quote
