The size of your solar system depends on how many amps you will use in a day. For example a 100W system will supply about 8.3 amps per hour (in the best conditions) So if you used 83 amps the night before it would take 10 hours of sunlight to recover the next day.
To calculate your usage take the amp rating of your fans, radio, chargers etc. and multiply it by how many hours you will be using the appliance. If a fan takes 3 amps to run and you use it for 10 hours then you have consumed 30 amps as an example.
Add in a little fudge factor and get a solar system a bit higher than your planned usage and you should be good to go.
