Old 09-19-2015, 12:05 PM   #1
PokerDealer's Avatar
Power/amps
I was reading an electrical site and they showed the amps drawn for typical items used in a TT. I noticed that the power boost antenna for my TV takes a lot of amps. I also noticed a green light on where I would hook up my TV (if I had one). My question is, does my power boost antenna use power even though it's not hooked to a TV?
2015 Wildwood 181 BHXL. 2005 1500 Ram Hemi 4x4 W/package
PokerDealer is offline   Reply With Quote
Old 09-19-2015, 12:27 PM   #2
Witch Doctor's Avatar
yes it hooked to the board in the antenna. just turn it off
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 09-19-2015, 12:31 PM   #3
Sc00ter's Avatar
Mine does. I turn it off when not in use for just that reason. I presume it is an amplifier.
2015 puma 295bhss
2009 ram 3500 6.7l ctd
Sc00ter is offline   Reply With Quote
Old 09-19-2015, 12:47 PM   #4
Thanks....... : )
Old 09-20-2015, 07:23 AM   #5
Herk7769's Avatar
Yes, the wall switch "routes" 12 volt power to the power supply circuits in the roof antenna amplifier (white box on the Winegard Sensar antenna models) via a powered closed relay and "deselects" the cable input on the outside wall when the green light is on.
When you turn it OFF, the wall plate relay is deenergized and 12 volt power is disconnected from the roof; the 12 volt power draw is then zero amps.
HAM CALLSIGN - KC3FFW
power
