Old 10-14-2015, 08:45 PM   #1
JoyMarie's Avatar
Power Awning Strut
We just purchased a used 2014 Shamrock 25rs and after getting it home I went to open the Dometic Power Awning and the left side didn't want to open. I then noticed that when it is in the closed position the very bottom of the awning arm sticks out from the camper a couple inches instead of being tight against the camper like the other side. If I push the bottom tight against the camper and pull out on the top as someone pushes the extend button then it opens with no problem. After inspecting it, all I can see is that maybe the strut(shock) on that side is worn out and needs replacing. Anyone have any experience with this or know of anything else it could be? I am new to these power awnings so it's all a learning experience for me. Thanks!
JoyMarie is offline   Reply With Quote
Old 10-14-2015, 08:50 PM   #2
The material is probably not centered on the roller. Deploy the awning and center the material and pop rivet the side hems to the tube.
Name:	Pop Rivet in Awning.JPG
Old 10-14-2015, 09:36 PM   #3
JoyMarie's Avatar
Awesome! Thank you!
Old 10-14-2015, 09:53 PM   #4
Left Coast
Remember, gas struts on these are stronger then they look, if tak'n 1 off.
Old 10-15-2015, 04:07 PM   #5
JoyMarie's Avatar
I checked to see if it was centered and it was. I really think it's the strut because when I pull each side down manually to tilt it, the left side is a lot easier to pull down than the right. Makes me think that the strut needs replacing.
Old 10-15-2015, 04:46 PM   #6
I replaced 1 strut on our Dometic awning be sure to also Order (6) Jesus retainer clips also! I had (1) other person Help me,at Goshen they had (4) Tecks to change a strut! It is a Job,and Be Safe! Youroo!!
power, awning
