Old 05-30-2009, 10:27 PM   #21
I found that if it rains with this set up, if you leave the black knob loose, it will automatically dump the water on the top pretty quickly! Mine had a small puddle in it, and when I loosened the knob, it dumped it out as the sliding mechanism slid in, and the edge dipped down. Pretty cool stuff! Randy
Old 05-30-2009, 10:45 PM   #22
Chris and Sara
SWEET!! Will try it out next weekend when we leave for TN!!
2004 F-150 with Tow Package
2009 Flagstaff 829 FKSS
Prodigy Brake Controller
Equalizer Hitch
renegaderailfan is offline   Reply With Quote
Old 08-29-2009, 08:14 PM   #23
Happy to Be Camping
Shawomet3's Avatar
Location: We live in Rhode Island, but our hearts are in New Hampshire
I tried to get one through my dealer, but have gotton no response from him. Any suggestions on how I can get a kit for my awning?
Shawomet3 is offline   Reply With Quote
Old 08-29-2009, 10:17 PM   #24
I contacted A&E/Dometic directly from the owner's manual phone # that I have, and spoke to a woman in customer relations that said you need to give your dealer the model and serial # from the awning that is located on a sticker on the arm with the motor. They then can call Dometic/A&E for the free kit. I heard however that they had a fire at their plant, and are experiencing some delays, but that is just what I've seen on here. GOOD LUCK! Randy
Old 09-07-2015, 05:45 PM   #25
Grey wolf 18 rb
I have lci power awning, do they make a pitch tiling replacement arm.
There is no model number on the awning arms.
SHG
Hossaman is offline   Reply With Quote
Old 09-07-2015, 08:40 PM   #26
derek6669's Avatar
I had the same problem with water build up . Here is my solution, went to the Dollar Store and purchased 2 dog tie outs. Connected bungie cord to the awning, 1 each end and them ran a racked tie down from the bungie cord to the dog tie outs. Just put enough pressure on the tie outs to make the awning tight, rain runs off , no more problem
derek6669 is offline   Reply With Quote
Old 09-08-2015, 05:51 AM   #27
Grey Wolf
Thanks Derek, thats what i have been doing from time to time.
A friends has that arm that folds down a little bit so he doent have to tie it down.
Looks like an easy change out if i could find the part,but will continue to use bunjee cords till then
Thanks again
awning
