06-16-2014, 05:41 PM
Power Jacks
I Have a 2013 Surveyor with a power jack, (model #1817941 today I used it so I could go to my RV dealer for a problem with my awning struts not working. When I wanted to un-hook my trailer in my driveway the power jack won't work. I tried the light on the jack, and it isn't working either. I looked at the fuse panel, but there is nothing that indicates that there is a fuse for the jack. The trailer is plugged in, so the battery should not be the issue.
Any ideas how to get this to work, I am leaving on vacation Wednesday. I have lower the jack manually.
06-16-2014, 05:47 PM
There should be an in line fuse/ circuit breaker and possibly resetable.
Follow the power wire from the jack to the battery.
TURBS
"Sabre owners united"
06-16-2014, 05:48 PM
Black in-line fuse on red wire.
Fonzie
06-16-2014, 06:29 PM
2007 WildCat 32QBBS
The ones I have installed use a circuit breaker. Like stated already above, follow the power wire to find an in line fuse. In a pinch pop out the plug on top and use the manual crank handle.
06-16-2014, 06:37 PM
My trailer has an inline "cocoon" fuse holder. About 2-3 times per year, I have to twist the wires going into it to re-establish contact.
06-16-2014, 07:14 PM
Thanks everyone. I was looking in the fuse box, didn't realize the power line had a plug with fuse. The fuse seems to be dead, so a trip to the hardware store tomorrow. Thanks to everyone for their helpful suggestions.
06-16-2014, 08:16 PM
Must be the day to have electric jack problems. DH was unhooking today and ours wouldn't work either. Fuse had blown.
2016 Freedom Express 281rlds
2013 Flagstaff Micro Lite 25DS
2014 Dodge Ram 1500
Days Camped 2015 - 20
Days Camped 2016 - 12
06-16-2014, 08:29 PM
Good deal. Go ahead and get a multi pack with wide range of amps. You'll be glad you did.
Sent from my XT907 using Forest River Forums mobile app
2018 Forester 3011 DS
06-16-2014, 08:31 PM
What causes a fuse to blow?
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
06-16-2014, 08:49 PM
Just checked with my son, he said that it actually didn't blow but the ends were not soldered good. Just bad fuse.
2014 Dodge Ram 1500
06-16-2014, 08:56 PM
a fuses job is to protect a circuit from a direct short to ground. it is the weak link in the system. a circuit breaker is very similar also with slightly different operation but in the end provides the same function.
let's make a simple light circuit. power must flow from the positive terminal of the battery through the lightbulb and then to the ground, the ground can be the trailer frame or a wire leading back to the negative battery terminal. a fuses is put in between the positive terminal and the load which in this case is a light bulb. a fuse needs to be placed as close to the battery connection as possible for proper protection. if you did not have a fuse and the positive wire were to touch ground it would arch in turn causing a dead short which can cause damage and possible explode the battery. basicly is is welding metal in a simple answer.
The fuse can blow from a direct short to ground, the fuse being lose in the holder causing heat in turn melting the fuse, the motor being shorted or bad, or a bad connection causing high resistance.
06-16-2014, 09:23 PM
I had a brake light wire going to the plug receptacle on my truck rub the casing off the wire, touched the frame somewhere and caused a fuse to blow. Had no brake lights and no trailer brakes. That was a fun trip!
06-16-2014, 09:26 PM
I believe the wire size in a circuit is selected to handle the current that the circuit requires. A fuse/circuit breaker is sized (amperage rating) and inserted in the circuit to protect the wire.
06-16-2014, 09:42 PM
Best way to fix it is replace the fuse/fuse holder with an automatic resetting circuit breaker of the same amperage.
