Old 06-16-2014, 05:41 PM   #1
Power Jacks
I Have a 2013 Surveyor with a power jack, (model #1817941 today I used it so I could go to my RV dealer for a problem with my awning struts not working. When I wanted to un-hook my trailer in my driveway the power jack won't work. I tried the light on the jack, and it isn't working either. I looked at the fuse panel, but there is nothing that indicates that there is a fuse for the jack. The trailer is plugged in, so the battery should not be the issue.
Any ideas how to get this to work, I am leaving on vacation Wednesday. I have lower the jack manually.
Suez is offline   Reply With Quote
Old 06-16-2014, 05:47 PM   #2
TURBS's Avatar
There should be an in line fuse/ circuit breaker and possibly resetable.
Follow the power wire from the jack to the battery.
TURBS
"Sabre owners united"
Old 06-16-2014, 05:48 PM   #3
fonzie's Avatar
Black in-line fuse on red wire.
Fonzie
Old 06-16-2014, 06:29 PM   #4
2007 WildCat 32QBBS
05CrewDually's Avatar
The ones I have installed use a circuit breaker. Like stated already above, follow the power wire to find an in line fuse. In a pinch pop out the plug on top and use the manual crank handle.
05CrewDually is offline   Reply With Quote
Old 06-16-2014, 06:37 PM   #5
Mr. Dan's Avatar
My trailer has an inline "cocoon" fuse holder. About 2-3 times per year, I have to twist the wires going into it to re-establish contact.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 06-16-2014, 07:14 PM   #6
Thanks everyone. I was looking in the fuse box, didn't realize the power line had a plug with fuse. The fuse seems to be dead, so a trip to the hardware store tomorrow. Thanks to everyone for their helpful suggestions.
Old 06-16-2014, 08:16 PM   #7
NKARENG's Avatar
Must be the day to have electric jack problems. DH was unhooking today and ours wouldn't work either. Fuse had blown.
2016 Freedom Express 281rlds
2013 Flagstaff Micro Lite 25DS
2014 Dodge Ram 1500
Days Camped 2015 - 20
Days Camped 2016 - 12
NKARENG is offline   Reply With Quote
Old 06-16-2014, 08:29 PM   #8
dcheatwood's Avatar
Good deal. Go ahead and get a multi pack with wide range of amps. You'll be glad you did.
Sent from my XT907 using Forest River Forums mobile app
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 06-16-2014, 08:31 PM   #9
Timex's Avatar
What causes a fuse to blow?
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 06-16-2014, 08:49 PM   #10
NKARENG's Avatar
Just checked with my son, he said that it actually didn't blow but the ends were not soldered good. Just bad fuse.
2014 Dodge Ram 1500
jacks, power
