Old 04-15-2016, 02:25 PM   #11
rracer5's Avatar
Originally Posted by roadking1997 View Post
Depending on the year, but my 2005 Duramax was wired with trailering package, but had a blank in the fuse slot under the hood for the 12v power. Just had to buy a large 50amp fuse and it was good to go.
X2....was the same on my 2002 1500HD except all I had to do was install the 40 amp MAX FUSE in the designated slot in the fuse box under the hood. I do know that GM changed things up in later years (as stated in previous posts) but, it's all still in/around the fuse box area under the hood. On my old 2002, when I opened the fuse box cover, the fuse location/slot diagram was under the cover and was labeled "trailer 1" and "trailer 2" I believe.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 04-15-2016, 03:14 PM   #12
Ham Camper's Avatar
I have a 2015 GMC Denali 2500 and I did not see any loose wire around my battery. I am getting this correct that I am NOT charging my TT battery when going down the road connected to the trailer? I need to investigate this further.
Larry W8PO & Lori N8IHJ and Louie the wonder dog
2014 Surveyor Cadet 265RLDS
2015 GMC Denali HD
Ham Camper is offline   Reply With Quote
Old 04-15-2016, 03:23 PM   #13
rracer5's Avatar
Check the "1 o'clock" position in you trailer plug to see if it's live (key off or key on). Sometimes they are already hooked up from the factory (trailer package) & sometimes it's left up to the dealer to hook up as part of there pre-delivery prep. but, they don't always remember to do this.
2014 Sanibel 3250
Old 04-15-2016, 03:25 PM   #14
Herk7769's Avatar
As part of dealer prep, the dealer is supposed to connect the power to the under hood fuse block. They did not do so on mine, and many others apparently.
Here is the tech bulletin on how to do it.
The wire is in a bundle taped underneath the battery.
You will need an M-6 nut and a 40 amp fuse (if it is not in the block already - mine was).
File Type: pdf Installing Auxiliary 12-Volt Feed to Trailer.pdf (457.4 KB, 66 views)
HAM CALLSIGN - KC3FFW
Old 04-15-2016, 03:45 PM   #15
TURBS's Avatar
Originally Posted by Tomgky View Post
I had the same issue with my 2012 Yukon The wire is taped up by the fire wall under the hood. It is red you need to open the fuse box under the hood and hook it up. The fuse (on mine is a 40amp) was already in place all I had to do is buy a metric nut and hook it up. I also found out that if you push the tow haul button while the engine is running it will boost the current to the TT battery.
Your passing blinker also goes from 3 flashes to 6!
Old 04-15-2016, 04:11 PM   #16
I installed a relay in the wire to my connector, and installed a switch in my dash so I can kill the power to the connector if and when I want to.
2011 Traverse LT, 3.6L, FWD
Old 04-15-2016, 04:16 PM   #17
Ham Camper's Avatar
Thanks everybody. I learn new stuff all the time on this forum. I read it every day.
2015 GMC Denali HD
Old 04-15-2016, 07:00 PM   #18
Thanks everybody!!!!!!!
Boomer1968 is offline   Reply With Quote
Old 04-15-2016, 08:49 PM   #19
Yes there sould be a red wire next to fuse block .Taped to harness. Install on stud at fuse block and check to see if trailer fuse is installed. GM tech.
Mahlstedtd is offline   Reply With Quote
Old 04-16-2016, 01:53 AM   #20
2007 WildCat 32QBBS
05CrewDually's Avatar
Check out this youtube video @1:56. https://youtu.be/x0x-2eKSmoM
This was the same for my 2011 Yukon Denali. You may have to hook up BOTH brake controller power wire & the trailer plug charge wire. Both were not hooked up on mine.
05CrewDually is offline   Reply With Quote
power, trailer
