Old 01-16-2013, 08:44 PM   #21
Originally Posted by wmtire View Post
I'm not saying that at all. The tanks and their capacities are most likely the same. The OPD (which stands for Overfilling Protection Device) is a safety measure to keep the tanks from getting filled with propane past their 80% water capacity.
Before you had the OPD, someone could fill the bottle with 25 pounds of propane if they didn't watch what they were doing.......and thus not have the 20% expansion space needed.
An OPD valve also will not allow propane out of the bottle unless the cylinder is attached to the appropriate hose. This would keep someone from blowing themselves up, if they forgot to fully close the cylinder valve, and gas was escaping.
Propane OPD - Overfill Prevention Device Cylinder Valves
Like I stated earlier, your tare weight and water capacity numbers are stamped on your cylinders. These are the numbers that dictate everything about your tank, and it's propane capacities.
Amerigas and Blue Rhino both have been sued for their misleading of customers about the cylinders only being filled to 75% of capacity. These companies have both misinformed the attendants at the places they have exchange stations, who relayed the lie told to them, to their customers.
Blue Rhino Pre-filled Propane Tank Litigation
AmeriGas Pre-Filled Propane Tank Class Action Settlement - Law Firm Stueve Siegel Hanson LLP Attorneys Kansas City, Missouri
so original tanks could be overfilled? i did not know that either how about when it is called a 5 gallon tank. is that 5 gallons of water-is that max?
gerrym51 is offline   Reply With Quote
Old 01-16-2013, 08:49 PM   #22
Herk7769's Avatar
Originally Posted by jimh View Post
that's what i was afraid of. what r they good for 12 yrs? i'll probably have to buy new tanks the next time i need them filled.
after a hydro, i'm wondering how u get them dry? do u just keep purging them or do u pull a vacuum?
That is what I was saying Jim. When I get close to the date, the tanks get exchanged at Lowes for new ones. I always ask the attendant to check the dates if he or she is not busy and get the "youngest" one.
HAM CALLSIGN - KC3FFW
Old 01-16-2013, 08:51 PM   #23
Personally I liked the old style tanks better. If the guy filling it paid attention it was not a big deal. I have had issues with the OPD valves sticking and getting no gas flow. Usually if you crack the valve slowly you won't have a problem. One thing I like even less is the CARB compliant gas cans! I would like to choke the guy that came up with them!
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Nights camped 2012 - 35
Nights camped 2013 - 46
rkswyo is offline   Reply With Quote
Old 01-16-2013, 09:23 PM   #24
jimh's Avatar
i might have to try that and hope.
jimh is offline   Reply With Quote
Old 01-16-2013, 09:23 PM   #25
ken0042's Avatar
Now that you know the process for having your tanks refilled, you can also take bathroom scales and check to see how much you have in your tanks.
Or a better option is a scale like This one. It's really handy to know exactly how much propane I have left in the tank. It's also priceless to pull into the refill place and ask for 13 pounds; and have the attendant ask how I knew that.
For me the biggest reason not to get pre-filled is that I am usually filling when the tank is not 100% empty. If the tank has 7 pounds left in it I am only paying for the 13 pounds it takes to fill it. Trading in would mean running the tank dry or losing what is left.
Wolf Pup T16P owner
"The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine." - Abraham Lincoln
ken0042 is offline   Reply With Quote
Old 01-16-2013, 09:34 PM   #26
OL Creeker's Avatar
Propane refills
Originally Posted by samm View Post
is it cheaper to refill your tanks or trade them in for prefilled tanks ?
If you read the tiny writing on exchanged tanks, you'll find you got cheated - legally. Our gov't, that's always looking out for us, determined a tank containing less than normally considered "full" is safer. It certainly helps the retailer!
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
OL Creeker is offline   Reply With Quote
Old 01-16-2013, 10:12 PM   #27
wmtire's Avatar
Yes, they could be overfilled. Here is an excerpt from the Good Sam link below about that.
RV Propane Tanks
There are limits on how much propane can be put into a cylinder. Because propane expands, as it gets warmer, it is important not to exceed a cylinder's proper filling limit. A properly filled cylinder will have a vapor space left in the top of the cylinder to allow room for expansion of the liquid with a change in atmospheric temperature. Currently proper refilling is dependent on the operator; it is possible to overfill the cylinder by inaccurate weighing, ignoring the presence of liquid propane at the fixed-level gauge, or relying on a float-type dial gauge. The OPD helps prevent potentially hazardous conditions caused by cylinders that may have been overfilled.
OPDs are intended to reduce the danger associated with these kinds of possible errors, by automatically stopping the refilling process without the operator's intervention. The new OPD valves prevent overfilling of gas cylinders, making filling and using gas cylinders safer than ever before. The OPD consists of a float mechanism attached to the cylinder's refilling valve that cuts off the flow of propane as soon as the propane level reaches the container's rated 80 percent liquid capacity. The presence of an OPD does not relieve the operator from the duty of determining the proper fill level by one of the other standard methods.
Now as far as calling them 5 gallon tanks, I am not sure and am just purely guessing. Maybe someone else can answer than really knows for sure. Propane weighs different amounts at different temps. It is 4.2 pounds per gallon at 60 degrees Farenheit according to some web sources I've seen. A 20 pound tank divided by 4.2 equals 4.76 gallons.....or 5 if you round off.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 01-16-2013, 10:34 PM   #28
B47
I totally agree. Refill that puppy.
The only time I use "replacement" is when a tank upgrade is available (like the new ones with the integral gauge) or my tank is getting close to the 10 year point and will need a hydro-static test (expensive) before it can be filled again.
I replaced all my old valve 20 pound tanks at Lowes and Home Depot when the brand new tanks hit the cages. I will swap them out at Lowes when I can get the brand new tanks.
The 30 pound tanks are refill only.
So they now made propane tanks with integral gauges - I didn't know that.
Anyone have any experience with them yet?
Old 01-17-2013, 06:09 AM   #29
wmtire's Avatar
Gerrym51, in the second weblink provided in post #13 of this forum it states the following:
How is propane weighed or measured?
Propane can be measured in a few manners. The most common way is by gallons. It can also be measured by pounds (1 gallon = 4.2lbs). When measured in gallons, a meter at the pump is used to determine the amount of propane that has been filled into a tank. When measured in pounds, the tare (empty starting) weight of the tank must be known first. After this weight is taken into account, the tank is then filled to capacity with the correct volume. (i.e. A BBQ tank is commonly referred to as a 20lb tank. This is because these tanks hold 20lbs, or approximately 5 gallons, of propane).
Hopefully, everyone who has been following this thread here, now know how to determine their propane capacities (and fill levels) of their various cylinders.
The people who exchange the tanks at Lowes, convenience stores, etc., do not really know/understand any of this, so I don't fault them too much. They were never trained to know this. They just relay the misinformation (aka propaganda) that Blue Rhino and/or Amerigas told them to tell the customers if anyone complained about the cylinders not being full (only having 15 pounds of propane). Using the OPD as an excuse with the fuzzy math, sounds plausible to the average Joe.......since John Q. Public doesn't know better.
However, that being said..............no matter how many times the lie is told, it doesn't make it the truth.
You just need to realize that when you exchange the tanks at most Blue Rhino or Amerigas places, you are only getting a 75% filled cylinder. It will be listed on the tag, just how many pounds are in the tank. The next time you walk by one of these propane exchange bins, take a look to see.
You can consider the lacking 25% as a convenience fee for being able to exchange the tank quickly and going on your way. LOL
Old 01-17-2013, 07:42 AM   #30
Capsfloyd's Avatar
My cousin works for a propane company , most of the time I can get mime refilled for free
They charge a flat fee for refills 30 # bottle is 37.50 ... No matter how much gas is in the bottle ?
2009 Rambox crew cab
2012 831 Flagstaff RKSS
2010 jeep Liberty
2010 Harley Davidson Ultra Classic
Capsfloyd is offline   Reply With Quote
