Old 02-11-2016, 09:38 AM   #1
B and B's Avatar
Propane Freeze Point
Hello All,
A fellow board member posed a question best answered by those in the know.
What temp causes propane to stop flowing properly?
My answer is Propane when a gas feed will not freeze but high flow can cause the regulator to freeze.
Normal TT use of standard tanks should not be an issue.
Also travelling in south many years ago a 30 lb tank was refilled with Butane/propane mixture as opposed propane and froze up north.
Is this still true?
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 02-11-2016, 06:44 PM   #2
Wobbles's Avatar
I have had a 20lb bottle connected to a double head heater mounted on top, not work this winter. The bottle was full but acted like nothing was in it. Checked it later when the temps got into the 40 degree range and all was working again.
I am in the St Louis, Mo area. What is up?
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 02-11-2016, 06:48 PM   #3
heavynlori's Avatar
We had same problem with two 100# tanks hooked to run one of those ventless wall heaters....
Used to shut itself off during night and we had a heck of a time getting it to relight most times
Gave up and took it out and put in wood stove
The problem was the tanks/regulator got too cold outside and no flow to heater....figured it out one day when sun beat on tanks later in day and it worked fine - too late, we already gave up fighting it 😁
Sent from my iPhone using Forest River Forums 🇺🇸
heavynlori is offline   Reply With Quote
Old 02-12-2016, 10:42 AM   #4
Head Rambler
Propane will stop vaporizing at -44F, so at that temp you won't get any gas flow even if it was in a open vessel. However, as it gets close to that temp the vapor pressure lowers toward atmospheric so an appliance that requires a large flow (i.e. furnace) can be starved enough that it won't be able to operate. The smallish regulators and gas plumbing in our RV's adds to the problem.
I've never actually tested it, but I'd suspect that somewhere about 10F below zero is about as cold as the furnace will operate.
Having said that, the volume of liquid in the vessel has a lot to do with how fast the vaporization occurs and exacerbates the flow problem at low temps.
Gotta go campin!
propane
