Old 05-03-2014, 05:03 PM   #1
Propane Quick Connect question
Our new trailer has a quick connect outlet along with a bbq. We don't want to use the BBQ that came with it and we also use a portable propane stove and mostly cook outside. We currently have the "t" that allows us to run two propane devises off of the tank. Can we get attachments that will work with the quick connect so we don't have to carry and extra propane tank? thanks for your help
BarbMarch is offline   Reply With Quote
Old 05-03-2014, 05:12 PM   #2
What most people have an issue with is having two regulators on the line. So you have the regulator on the tank and the regulator on the device you are using and it results in a low LP pressure. If you want to remove the regulator from the device you are using it should work fine. The pressure would be the same even with two devices connected as long as they aren't running threw the extra regulator.Campimg world has the quick disconnect to get you started. Lowe's or any hardware will also have the part to make your own.
Old 05-03-2014, 05:26 PM   #3
AquaMan's Avatar
I mounted a full size grill on the back of my 5er and removed the regulator and hose from the grill and mounted quick connect directly to the grill, then have a hose with quick connects on both ends. Works great. I also have a high pressure quick connect at the front, right off the tank, for use with a high pressure propane fire pit
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 38
Old 05-03-2014, 06:21 PM   #4
Aqua what fire pit do you use? I just received the Big Red and live it but I use a 20# tank for fuel. It's to much hassle moving the MH to refill the house tank.
Old 05-06-2014, 03:50 AM   #5
AquaMan's Avatar
I use one I bought from Sam's Club, $49. Have used it for 2 seasons and works great. I think it's 55-60k BTU, so it does put out a decent amount of heat if you want it. I actually bought a spare that's sitting on the shelf for when this one dies.
Old 05-06-2014, 05:12 AM   #6
Thank you for the responses. We are going to see what we can do.
propane
