Old 11-11-2016, 08:43 PM   #51
Thurman's Avatar
I learned from an older, more experienced camper: Use colored zip ties on your LP bottles. Place a green, orange or yellow, and a red zip tie on the handle of your bottle. If you see a green one on the bottle-it's full. If you see a yellow or orange one on the bottle it's in use. If you see a red only on the bottle it's empty. This works only if you remove the zip ties are properly removed
2015 FR Freedom Express 310BHDS pushing a 2014 GMC Sierra CC
Thurman is offline   Reply With Quote
Old 03-06-2017, 02:06 PM   #52
wicked1's Avatar
Originally Posted by trbomax View Post
Sams club sells new ones WITH a float gauge for $29.95 too.I just bought 4 of them.I will keep one of the tanks that came with the 5er and probaly give the other one away.
Yeah BJ's does too and I just got one for home BBQ it seems to be accurate
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 01-11-2019, 10:10 AM   #53
wmtire's Avatar
I was needing some propane for our shop heater this morning, and was debating just exchanging a cylinder across the road at a dollar general. Their price was total of $22.09 but only had fifteen pounds of propane as we have discussed previously.
When I did the math that is $1.47 per pound. Decided it was just too much cheaper to drive the 1 and a half miles to my local tractor supply, where I can get it all the way filled with twenty pounds, for $2.49 a gallon, or between 0.62-0.65 cents a pound depending on their meter. Their meter will show anywhere between 4.5-4.7 gallons to fill my empty twenty pound cylinders.
So tractor supply is less than half the price per pound of propane vs the exchange across the road. Pretty good price difference.Click image for larger version
2011 Flagstaff 831 RLBSS
I hate it when people don't know the difference between ur and u'r!
Old 01-11-2019, 10:42 AM   #54
rracer5's Avatar
So tractor supply is less than half the price per pound of propane vs the exchange across the road. Pretty good price difference.Attachment 194375
$2.49/gal. seems a little high right now. Last time I went to Costco (3 weeks ago) propane was $1.97/gal. & that was down $.28 since October. I filled up 1 30 lb tank (7.1 gal.) and topped off another (4.6 gal.) for under $24. Just sayin' that that seems like a pretty big price spread from 2 large chain retailers. I have to go again today so, I'll edit this post once I get back.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 01-11-2019, 11:55 AM   #55
$2.49 is high because it's the price for a tank exchange for a not-full tank, which was wmtire's point. First they charge more for the "convenience" of simply exchanging a tank rather than waiting around for it to be filled, then they charge you even more because they don't actually give you a full tank.
Since you filled your own tanks, then wmtire's $1.47 price is closer to what you should have paid. Looks like you paid $2.05 for 11.7 gals. So you still paid almost 40% more than wmtire did.
2011 Traverse LT, 3.6L, FWD
Old 01-11-2019, 12:03 PM   #56
wmtire's Avatar
Tractor Supply here has been averaging that price for a little bit. It was $2.59 per gallon around Thanksgiving.
We don't have a Costco nearby, so I can't get it as cheap as you are.
Old 01-11-2019, 12:06 PM   #57
wmtire's Avatar
Rockfordroo, the $2.49 is the refill price per gallon at tractor supply....or about 62-65 cents per pound.
Way cheaper than $1.47 per pound at the exchange.
Just wished I had a nearby Costco to get for under $2 per gallon. rracer5 got his cheaper per pound at Costco than I did at tractor Supply.
Old 01-11-2019, 12:09 PM   #58
I failed to catch the gal vs lbs. So ignore my calculations, but keep my comments regarding increased cost for tank exchanges.
Old 01-11-2019, 03:31 PM   #59
rracer5's Avatar
OK, I'm back. Couldn't edit above cause time lapse was too long so..... Costco is now $1.89/gal. I got 2 30 lb. & 1 20 lb. tanks filled/topped off. Total of 14.7 gals., $27.84.
Going to be chillier than normal here in Myrtle Beach so, we'll see how long this will last.
2014 Sanibel 3250
propane
