12-22-2014, 10:27 PM
Propane tanks
Do you guys fill tanks up while in storage?
12-22-2014, 10:30 PM
Ret E-9 Anchor-clanker
Can you take them out?
12-22-2014, 10:31 PM
Yes
12-22-2014, 10:32 PM
Let me rephrase. Do you store them full?
12-22-2014, 10:38 PM
I do. Never had any problems.
12-22-2014, 10:49 PM
I did the first year, but since then I haven't....this fall I put it in storage with one empty tank...no particular reason why, just figured why fill it when I won't need it till spring...left myself a note inside trailer that it's empty in case I forget in the spring..happens as the brain gets rusty!
One reason for not filling it was because propane was higher in price than normal this fall, and thought perhaps it may do as gasoline and drop over winter, so will fill it in the spring. I have stored our outdoor grill tanks empty over the winter and they have never given me grief so figured this would be the same.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
12-23-2014, 11:23 AM
Yes, Want to make sure that check is in the box. Theirs enough cost that creep up on you when prepping the spring trips. Never had any problems.
12-23-2014, 11:30 AM
AKA: 'tiredTeacher
Our TT sits idle for about two months (Jan. - Feb.) so I put 'er to sleep as is as far as the propane is concerned.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
12-23-2014, 11:32 AM
Some people say to top them off, others say does not make a difference. I am still new at this camping thing. We have a 330 MKS 5ver and still in the learning curve.
12-23-2014, 11:37 AM
Dazed & Confused
When a tank goes empty, I have it filled at first opportunity. That is my method. Now I store my TT on my property so it does not matter, but my son stores his pop-up at our local fairgrounds, all inside storage, and propane tanks must be removed before storing.
BTW I use my propane BBQ all year round and it sits on my deck all winter. Same policy, when tank goes empty, I have it filled.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2020 Ram 2500 6.4L Crew cab 4WD, 4.10 Axel
12-23-2014, 11:38 AM
When planning the known cost of winterizing I.E. antifreeze, anode rod, propane, battery tender, fiberglass insulation, duct tape, bungee cords, permanent covers.......
12-23-2014, 11:41 AM
I didn't quite understand the auto-switchover gas regulator, so I ended up emptying both tanks in my 3rd season, so both tanks were in some state of discharge over two winters. (I'm guessing the first was partially full the first winter and empty the 2nd winter.)
2011 Traverse LT, 3.6L, FWD
12-23-2014, 01:12 PM
i just leave them on the trailer, with whatever i ended the season with.
i refill when we start camping in spring.
12-25-2014, 02:44 PM
Retired
Leave them which ever way you want... You're not going to be wrong either way...
2014 Chevrolet Silverado 3500 LTZ CCLB DRW D/A - Rancher Grille Guard - Transfer flow 40 gallon Toolbox/Tank Combo - Line X - Edge Insight
2015 Palomino Sabre 33CKTS - Platinum Edition - Progressive Industries EMS HW50C - JT Strong Arm Stabilizers - Ground Control 3.0 - 320 Watt Solar with 2000 Watt Inverter
12-25-2014, 04:25 PM
I have a propane gauge that I attach to the tanks to see what is left in them when I open it up in the spring, that way I know if I have to fill my tanks or I'm good to go. The gauge doesn't cost that much and you can get them at places like General Trailer. Nice to keep with your unit so if you are camping you can check the level periodically. JT
