Old 12-22-2014, 09:27 PM   #1
CMSgt. (Ret) Charlie Brown
CMSgt (Ret) Charlie Brown's Avatar
Propane tanks
Do you guys fill tanks up while in storage?
CMSgt (Ret) Charlie Brown is offline   Reply With Quote
Old 12-22-2014, 09:30 PM   #2
Ret E-9 Anchor-clanker
donanddona's Avatar
Can you take them out?
donanddona is offline   Reply With Quote
Old 12-22-2014, 09:31 PM   #3
Yes
Old 12-22-2014, 09:32 PM   #4
Let me rephrase. Do you store them full?
Old 12-22-2014, 09:38 PM   #5
arpipeliner's Avatar
I do. Never had any problems.
arpipeliner is offline   Reply With Quote
Old 12-22-2014, 09:49 PM   #6
WFD
I did the first year, but since then I haven't....this fall I put it in storage with one empty tank...no particular reason why, just figured why fill it when I won't need it till spring...left myself a note inside trailer that it's empty in case I forget in the spring..happens as the brain gets rusty!
One reason for not filling it was because propane was higher in price than normal this fall, and thought perhaps it may do as gasoline and drop over winter, so will fill it in the spring. I have stored our outdoor grill tanks empty over the winter and they have never given me grief so figured this would be the same.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 12-23-2014, 10:23 AM   #7
donanddona's Avatar
Yes, Want to make sure that check is in the box. Theirs enough cost that creep up on you when prepping the spring trips. Never had any problems.
Old 12-23-2014, 10:30 AM   #8
AKA: 'tiredTeacher
awellis3's Avatar
Our TT sits idle for about two months (Jan. - Feb.) so I put 'er to sleep as is as far as the propane is concerned.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 12-23-2014, 10:32 AM   #9
Some people say to top them off, others say does not make a difference. I am still new at this camping thing. We have a 330 MKS 5ver and still in the learning curve.
Old 12-23-2014, 10:37 AM   #10
Dazed & Confused
M&K Hoffman's Avatar
When a tank goes empty, I have it filled at first opportunity. That is my method. Now I store my TT on my property so it does not matter, but my son stores his pop-up at our local fairgrounds, all inside storage, and propane tanks must be removed before storing.
BTW I use my propane BBQ all year round and it sits on my deck all winter. Same policy, when tank goes empty, I have it filled.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
propane, tank
