Old 12-16-2006, 07:20 AM   #1
Question Proper Jack Placement
Hello:
Checked the manual for Surveyor TT could not find anything about Jacking up the trailer, should jack be placed under axle or frame. Does anyone have this info?
Thank You
JG
James Gibbons is offline   Reply With Quote
Old 12-16-2006, 08:32 AM   #2
milzat's Avatar
James,
Your Surveyor is equipped with a Independent Torsion Suspension System.
Caution should be taken when jacking the trailer. A jack should be placed as far outward under the axle-to-frame mount as possible. Placing a jack anywhere else could mis-align the Camber of the axle and lead to premature tire tread wear.
What I'm saying is, try to place the jack in the area where the axle is bolted to the frame.
This is where I placed a jack, on a previous TT I had, with Torsion axles.
The photo below is of a Forest River trailer with Torsion axles. Should be very similar to yours.
milzat is offline   Reply With Quote
Old 12-16-2006, 01:25 PM   #3
Smile Jack Position
Hello Mike:
Once again thank you for the info. I'm glad I didn't go rasing the trailer and do some damage.
JG
Old 10-04-2007, 05:58 AM   #4
I know this thread is from last year, but I just raised my camper to change out an axle. I used a device called an E-Z JACK. It is safe to use. It is not recommended to jack up a camper from what I read. The E-Z JACK came from camping world.
Old 10-04-2007, 07:52 AM   #5
RAC
single axle or dual? If dual, you can make a little ramp and block to raise one axle off the ground which raises the 2nd to work on.
RAC is offline   Reply With Quote
Old 10-04-2007, 09:22 PM   #6
welshman599's Avatar
Send a message via MSN to welshman599
Great illustrations Milzat!!
  • Salem 401-2b; 31" Sony Trinitron and two channels on the antenna.
  • Smokin' hot wife... 2 boys, 25 and 10.
83 sweet sweet days camped in 2008 - not easy in my neck of the woods!
welshman599 is offline   Reply With Quote
Old 10-04-2007, 09:52 PM   #7
milzat's Avatar
Thanks. welsh.
The EZ jack is probably safer to use.
There's also the Trailer Aid.
Old 10-05-2007, 06:24 AM   #8
I use leveling blocks stacked into a pyramid.
same concept as using the EZ jack
aintgotnun is offline   Reply With Quote
Old 10-05-2007, 07:38 AM   #9
RAC
BWEAHAHAHAHAHAHAHAHAHAHAH I answered a thread from last year! LOL!
