Old 07-30-2014, 01:49 PM   #1
mwoods's Avatar
Puma 30QBSS
Got the Puma home and set up.
I do not have a RV plug at the house yet. (will call handyman asap)
Tried a 20 amp household circuit and that works if the A/C isn't turned on.
Hooked up my 5500 watt generator and that worked for awhile running the A/C but then the breaker on the generator started to pop. This is plugged into the 30 amp service on the generator and using a pig to plug the RV cord into that.
It is extremely hot in central Florida today and the generator was in partial shade. So maybe the heat is affecting the generator also.
It took me awhile to get the fridge to fire up. The propane would not kick in even though the tanks say they have propane in them. After messing with it for awhile and almost passing out from the heat I got it running.
All it needed was for the connectors to the tank valve taken off and screwed back on and propane flowed firing the fridge.
Hot water heater works, no leaks observed anywhere.
The battery needs to be replaced, former owner says it is the original from 2008. The trailer lights flicker on battery power only .
I used my black and decker 12 volt drill to lower the leveling jacks, is there a more powerful drill that will actually move the trailer jacks up and down to level it? The former owner said something about a hammer drill???
Oh, and what do DH DW mean? I know the husband and wife but the "D"??
Photo of course
mwoods is offline   Reply With Quote
Old 07-30-2014, 01:59 PM   #2
billt01's Avatar
Well...the the D usually stands for darling...
But in my house its usually the "da%$ husband" and my "delightful wife"
"Camping invloves a tent, bugs, and incliment weather. This aint camping"
-Bill Thomas
Palomino Solaire 317 BHSK
billt01 is offline   Reply With Quote
Old 07-30-2014, 02:00 PM   #3
Kaadk's Avatar
RE Drill: My Brother In Law (BIL) uses a corded drill instead of a cordless to be able to get the extra torque.
RE DH, DW: Stands for Darling. It seems to be the accepted form of short-hand on this forum, whether or not the spouse is actually "darling".
RE RV plug at home: There's a diagram somewhere in the library about how to properly wire these plugs. Be sure to provide it to your handyman. It seems a lot of them end up wired for 220 instead of 110 which could then fry the trailer.
Oh, and of course... Congrats on your new trailer. Hope you have many happy camps with it.
There's no use crying over spilt milk, unless it's on your keyboard.
Kaadk is online now   Reply With Quote
Old 07-30-2014, 04:07 PM   #4
mwoods's Avatar
Reading another post I see that the generator is 30 amps at 220 volts and 15 amps at 120 volts. There lies the issue with the generator.
TV 2012 Chevrolet Silverado CC 5.3
TT 2007 Puma 30QBSS
Reese 12000 WDH
Reese Anti-sway bar
Old 07-30-2014, 04:17 PM   #5
Congrats on your Puma 30QBSS. Thanks for the pic. Here's a couple links to RV shorthand:
Shorthand
https://sites.google.com/site/jdbeastlet/acronyms
Old 08-06-2014, 01:23 PM   #6
GASPEDDLER's Avatar
Congrats on your PUMA, we love ours!
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 08-06-2014, 01:31 PM   #7
Rugged Brown's Avatar
"Levelling" jacks is a misnomer. At best, they can be used to stabilize the camper once levelled, but do not think that you can level your camper with these jacks. They will bend and break under the weight of the camper.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 08-08-2014, 04:56 AM   #8
mwoods's Avatar
Got 30 amp service installed just to the right of where the TT is parked.
I was able to inspect the roof and see that NO preventative maintenance was done.
This is the edge of the roof at the metal seam.
I sure wish I would have insisted on a roof inspection prior to purchase, just to haggle the price down.
The slide out roof.
Cleaned the roof with car wash soap with a dash of bleach in it and then the whole TT with car wash soap. Rinsed off well, no leaks detected at all on the inside.
A trip to Campingworld yielded Dicor and SticknBond along with other goodies.
Ace Hardware for Denatured Alcohol and will get the roof caulked and sealed up today (Friday)
TT 2007 Puma 30QBSS
Reese 12000 WDH
Reese Anti-sway bar
Old 08-08-2014, 10:59 AM   #9
DO NOT USE THE JACKS TO LEVEL THE TRAILER! These are stabilizing jacks only. You level from under the tires (Giant yellow leggo block looking things).
If you level with the stabilizer jacks they will break and you will go bump in the night. And then head for an RV body shop to do the repairs. I tried to warn a guy once, said he'd been camping 15 years doing it this way and I should just shut up. I should have a taken a picture of his trailer trying to a wheelie 2 weeks later!
David 01 is offline   Reply With Quote
Old 08-08-2014, 05:05 PM   #10
mwoods's Avatar
Thanks for the info, got it on the leveling....
Long ass day but got the roof and slide out done. SticknBond on the roof of the slide out with some Dicor thrown in and the edges of the TT roof sealed up with Dicor. Hit the front and rear seams and any other spot that was cracking.
Dremeled the bathroom door latch so the door will close now.
Refastened one of the bases of the table to the floor as it was pulled off as the screws were stripped.
Next to do is take the cover off of the A/C and clean the interior.
TT 2007 Puma 30QBSS
Reese 12000 WDH
Reese Anti-sway bar
puma
