Old 06-19-2015, 07:15 PM   #1
Question
What is this and how do I open it? Got wasps living in it.
wildtigger2 is offline   Reply With Quote
Old 06-19-2015, 07:17 PM   #2
Mowgli64's Avatar
That is your refrigerator access panel. The 2 black rectangular knobs in lower corners turn 90 deg and should be able to pull out from bottom first.
2015 Wildwood X-Lite 271RBXL
2013 Ford F150 Crewcab Ecoboost
Mowgli64 is offline   Reply With Quote
Old 06-19-2015, 07:18 PM   #3
Flybob's Avatar
That is the guts of your Fridge. Critters can prevent it from working. Suggest you get screens for the vents. You should also put a screen on the furnace vents as well.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-19-2015, 07:24 PM   #4
Where can I get some at? How to put it on? I'm in Casper Wyoming camping for another week.
Old 06-19-2015, 07:28 PM   #5
Can I use spray to get rid of the critters in there?
Old 06-19-2015, 07:28 PM   #6
arpipeliner's Avatar
Says you are in Texas. Wait till night or early morning. As previous mentioned screwdriver should turn the slotted portion 90 degrees and they should be able to slide out.
If me I would do above mentioned at late night wearing long sleeves and gloves without shining light into it and in early morning take out the panel unless it comes out at night and attack with wasp spray in the morning to kill the whole nest and remove it. Then put aluminum screen wire with duct tape to prevent it again. Make sure to get drain tube outside to not allow water inside the wall.
arpipeliner is offline   Reply With Quote
Old 06-19-2015, 07:30 PM   #7
Where can I get the screen wire at? Do I duct tape it to vent or just over the insides?
Old 06-19-2015, 07:42 PM   #8
geezer with gadgets
757Dave's Avatar
Here's what I use. Hope this helps.
Robot Check
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 48
757Dave is online now   Reply With Quote
Old 06-19-2015, 07:44 PM   #9
I've also heard of people hanging flea collars inside the the opening behind the door on refrigerator & water heater. Just make sure it isn't touching anything gas or electric; won't work on furnace. You can buy screens at camper supply stores to fit everything.
Papa GLS is offline   Reply With Quote
Old 06-19-2015, 08:17 PM   #10
mark0224's Avatar
If your going to spray use one that is in fog form not in a stream that way you won't have a big mess to clean out after.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
