Old 02-26-2015, 12:39 PM   #21
BigTJohn's Avatar
I had the same as OC. They worked well on my lighter trailers but not so much on the 5th whl. They will "roll out" with enough torque but remember the rubber in the tire will deform enough for that to happen, just takes a lot of pull to do it. I would always use both, anti roll chocks and the XChocks.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 03-02-2015, 04:29 PM   #22
WatkinsGlenCamper's Avatar
I use both "under wheel" chocks and wedge type chocks I built about 6 or 7 years ago. The chocks I built have always worked good and my RV has never moved with them tighten. They are very adjustable and uses a small load binder to tighten the treated wood wedges. Here's a photo:
2013 Micro-Lite 23LB
2016 Ford 4X4 F150
...and 4 Old Wooden Boats (Penn Yans)
https://www.glenphotos.com
WatkinsGlenCamper is offline   Reply With Quote
Old 03-04-2015, 06:07 PM   #23
We use just wheel chocks, have looked at the others for a couple of years and wondered if just a gimic, but from comments here it seems this maybe the ticket to stop the inside rocking.
Kevin
tenttotrailer is offline   Reply With Quote
Old 03-04-2015, 06:25 PM   #24
Always Learning
I use RotoChoks and must not tighten them enough. I had them pop-out one day I tried to move the camper (drove over the chock and bent the handle ). And now, they seem to let the camper move some. So I use both- cheap crappy plastic ones and my Rotochoks.
Old 04-27-2015, 06:29 PM   #25
dsjohns71's Avatar
Does anyone have any experience with the Fastway ONEstep chocks? If so are they any good?
dsjohns71 is offline   Reply With Quote
Old 04-27-2015, 06:46 PM   #26
LANShark42's Avatar
I've seen their . I think the Bal X-Chocks make more sense. And they're cheaper. Just my 2¢... YMMV
19xx Wife (named Melissa)
2014 Akita (named Mizuki)
2015 F250XLT 6.2l V8, 4x4, Supercrew, 3.73 Rear
10K WD Equal-i-zer Hitch
2015 Coachmen Catalina 273BH
LANShark42 is offline   Reply With Quote
Old 04-27-2015, 06:50 PM   #27
danielabram71's Avatar
I just got a set of the bal x-chocks and they are really nice. Easy to use. And most of all they work!!
danielabram71 is offline   Reply With Quote
Old 04-27-2015, 07:52 PM   #28
dsjohns71's Avatar
With either type, I'd need the XL as my TT had the wide track (or what ever it is)axels. I just worry about (and read) the x-chocks damaging the tire, but I suppose common sense goes a long ways...huh.
Thanks for the quick responses.
Old 04-27-2015, 08:10 PM   #29
Don't know how the Bal X chocks can damage tires. Have used them for 9 yrs on 3 different trailers.
Old 04-27-2015, 08:16 PM   #30
Toby's Avatar
Originally Posted by OldCoot View Post
I use Bal X Chocks and evidently I tighten them more than KyDan because I also use them for the hitch pull test. Of course I only have a weak kneed 1/2T, but it cannot move the trailer with the X Chocks in place. Don't use anything on the ground to block the tires.
X Chocks are the 1st thing on when we park and the last thing off before we pull out.
I'd also like to use mine before I unhook but the instructions say otherwise. So I use the cheap-o plastic ones until the trailer is level and then put the xchocks on...same but reverse when leaving.
2018 Ford F250
2019 Arctic Wolf F295QSL8
Toby is offline   Reply With Quote
Old 04-27-2015, 08:19 PM   #31
vinmaker's Avatar
I agree. Wedge the tires with cheap plastic wheel chocks and then X chock the tires.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 10000#
Old 04-27-2015, 08:54 PM   #32
dsjohns71's Avatar
Good to know.. Thanks OC
Old 04-27-2015, 08:55 PM   #33
mark0224's Avatar
I like both working together
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 04-27-2015, 09:02 PM   #34
Buddy of mine was rather "ill" one morning while packing up and was about to leave with still in place on his 5'er... A friend was sitting in his lawn chair and said "Just wait I wanna video this!".. The hungover one looked and saw what he was about to be famous for..
That's as close as I know of...
We love our X Chocks.. They definitely take alot of the movement out of the TT..
Camped: 2024 (Days/Nights) - 4/3
2023 (D/N) - 34/27, 2022 (D/N) - 41/33, 2021 (D/N) - 37/29, 2020 (D/N): 58/49
TT: 2020 26' Hemisphere 26BHHL
TV: 2020 GMC 2500HD 4x4
glen1971 is offline   Reply With Quote
Old 04-27-2015, 09:14 PM   #35
Iwannacamp's Avatar
Ok. I will say it... How long does it take to kick some insurance I front of/behind the tires. If chocks ever stopped ONE trailer from rolling on accident...then it's good insurance. That being said..I use both as recommended here. I really don't notice the difference in the rocking...but the DW does...so that's good enough for me.
2017 Puma 297RLSS
