valve stems...
I successfully used the TST flo-thru sensors with rubber valve stems for about 18 months and 4,000 miles until I changed tires and replaced the rubber stems with metal valve stems. I have read here that others have done this also...
metal valve stems are better all-around, but don't change your rubber ones out until you have tires serviced or balanced... then you many want to ask you tire dealer if they have them in stock... you can buy them on amazon at a lower cost and have them installed...
I used these on my 14" aluminum rims
2014 Shamrock 183
