Old 11-12-2011, 06:01 AM   #1
Brigitte
boubou's Avatar
quick leveling question
got a pad built for trailer, down to the rock, the gravel, then fine gravel.
trailer not perfectly level on it, still need 1 lego block under tires on door side. Need to adjust the pad next spring. In the meantime, question is, how level should level be? I'm off maybe 1/3 on level. (lift level 1/3 inch for bubble to be centered)
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
Old 11-12-2011, 06:26 AM   #2
Boyd's Avatar
If you can walk around inside your trailer and not feel like you've drained the beer keg, you are level enough.
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
Old 11-12-2011, 08:41 AM   #3
Lottery Non-Winner
Ovair's Avatar
I like to be really level. I use one of these round levels and so long as the bubble is inside the ring, I'm good enough.
The bubble does not have to be exactly perfectly in the middle.
I place it on the center of the range top, and then I double check it by placing it inside the freezer. The stove and the freezer are two spots that should be plumb to the chassis (or so I have always believed).
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
Ovair is offline   Reply With Quote
Old 11-12-2011, 08:45 AM   #4
Fire Instructor's Avatar
Like Boyd said, it really isn't critical. Besides feeling awkward or intoxicated, being too far off level will affect slide operation, and force the fridge to work a bit harder. A single lego needed is only a one inch variance, over an almost 8' wide span, slightly more than a 1% variance. I've been forced to camp for a week at a time worse than that!!
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
