Old 03-16-2015, 03:37 PM   #1
Raccoons and bumper mount grill....
I discovered over Spring Break that if you cook burgers on your outside grill and leave it mounted there overnight, raccoons will climb all over it, turn the gas on and drain your propane tank. Have I mentioned I hate raccoons???
Old 03-16-2015, 03:41 PM   #2
Fulltime family RVer
At home, our last grill had to be replaced because raccoons kept chewing through the propane lines. They just wouldn't . Now we have one that has a fully enclosed bottom to protect the lines from the little jerks.
ependydad is online now   Reply With Quote
Old 03-16-2015, 03:44 PM   #3
TURBS's Avatar
Two words "coon candy"
Old 03-16-2015, 03:48 PM   #4
Kaadk's Avatar
Never had that problem with my grill, but I always clean it before turning it off.
My garbage can with the animal proof lock on the other hand they dragged across the site and out into the brush before I finally got fed up of scaring them off and put it inside the trailer.
Old 03-16-2015, 04:05 PM   #5
We used to hang our trash on the lantern poles provided at most of our state parks......until we had a coon actually shimmy up the metal pole and tear into it. Craziest thing I've ever seen. And yes, I actually saw it because he did it in broad daylight right in front of us. Now we have a joke about "Shimmy Coon".
Old 03-17-2015, 12:48 PM   #6
brer_rabbit10's Avatar
Rather than tie the trash to a pole try hanging a line between two trees (or whatever) and hang the bag from the center. Used to do this backpacking to discourage bears.
Bill Case
Silverback 35QB4
F350 Diesel prime mover
brer_rabbit10 is offline   Reply With Quote
Old 03-17-2015, 01:09 PM   #7
Flybob's Avatar
Check to make sure the grease is not running down the propane hose or that you are not connecting or disconnecting the hose with food ( grease) on your hands. The raccoons and squirrels will chew the hose because they smell the food on it. You might also order amazon book Seven tasty ways to prepare raccoon.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-17-2015, 01:48 PM   #8
Stormrider151's Avatar
Opposing thumbs should be for humans only. Just saying.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 03-18-2015, 06:30 PM   #9
trikebubble's Avatar
Our overnight tree guests love BBQ.
"Anywhere I roam, where I lay my head is home"
Days camped in 2014 - 35
Days camped so far in 2015 - 30
trikebubble is offline   Reply With Quote
Old 03-19-2015, 07:04 PM   #10
King Yankee's Avatar
Send a message via AIM to King Yankee Send a message via Yahoo to King Yankee
Always always turn the propane off at the source when not being used. Please always, a safety factor.
Bruce & Nancy Richardson
Lexington GTS 300 S/S
Chevy Avalanche
Jeep Wrangler
Honda Goldwing
King Yankee is offline   Reply With Quote
mount
