Old 12-10-2015, 01:09 PM   #11
Originally Posted by Mr Havercamp View Post
Any idea how high the winds were?
I don't mean to flame the transport drivers as a whole, but I travel daily on a 60 mile section of the PA turnpike and I usually come upon RV's being transported a couple of time a week. A fair percentage of those transporters are not the most careful and courteous drivers on the road from what I have witnessed. Also, since most ST tires have a 65mph limit on speed you would think that professional transporters would know and follow that? Not really.
What do they care...Time is money. They don't make very much to start with and going 65mph will cut into their paycheck...Most of them don't stay in the business very long and move on to better paying jobs.
GOTTOYS is offline   Reply With Quote
Old 12-10-2015, 01:17 PM   #12
BamaBob's Avatar
Originally Posted by nomad297 View Post
This happened on I80 in Montana or Wyoming. High wind warnings were in effect.
Bruce
Originally Posted by Bama Rambler View Post
I've seen the wind flip a few semi's and even a couple of train cars in Wy.
A slightly windy day to those folks is a hurricane to us. :-)
X2 Bama
We lived in Las Cruces, NM for over 13 years. Like Bama, I've seen everything from a MoHo to a semi blown over on the road. When, as Bruce said, High Wind Warnings are in effect, get off the road and try to find some sort of shelter from the wind (the lee side of big buildings comes to mind).
Spring in South NM/West TX can see sustained winds of 50+ MPH with gusts to 70MPH
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 12-10-2015, 01:30 PM   #13
TURBS's Avatar
Originally Posted by Cowracer View Post
if the wind can turn one over standing still (it happens) then rolling down the freeway will make no difference at all.
Mathematically, (using Turbs' new 320RS as an example) you have a length of 38 feet and a height of 12.5 feet. The roof slopes, so lets figure an average height of 11.5 feet. That gives you a skosh over 435 square feet of sail area. With a GVWR of 14300 that works out to 32.75 pounds per square foot, or .22 pounds per square inch of sail area.
Using the conversion of PSF/.00256 (standard PSF to MPH at sea level formula) you can see that to completly offset the weight of the camper you need about 112 MPH. At that point, you probably got bigger problems than worrying about your camper. But it only takes about 61MPH to display 1/3 of that campers weight. 61 MPH crosswinds are common in certain locations. If you hit one, you just side-loaded your truck to the tune of about 4300 lbs. (not including the sail area of the truck itself). Look at it this way. You will now have a GE J85 Turbojet engine in afterburner sitting cross ways on your pin box. You WILL depart your direction of travel. And while I cant calculate the center of mass of the camper, as it is higher than the center of rotation (the road) in the roll axis, you have also generated a significant roll moment. If your center of mass height is over 1/3 the total height, then that would be enough to roll you over on your side.
Driving skill, attention or experience has nothing to do with it.
Tim
Lol
Old 12-10-2015, 01:48 PM   #14
transamz9's Avatar
All I can say is that pulling a 5er of that size he needed a Dually. You know they are more stable than a SRW.......
2005 Ram 5.9 AT SB QC (Retired)
2010 Ram 6.7 G56 QC CC Aluminum flat/Leveled (Sold)
2008 Nitro Z9 towed by a 2015 Sanibel 3601 towed by a 2013 Ram 3500 SRW CCSB Cummins
2006 EZ GO 6" lift
transamz9 is offline   Reply With Quote
Old 12-10-2015, 01:55 PM   #15
Tim
I was not aware that there would be math on this thread. can we all go back to talking about half truths based on hearsay and truck brand loyalty?
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 12-10-2015, 02:06 PM   #16
Assistant TP Supervisor
B and B's Avatar
Brand of truck has nothing to do with it in this case. The Redwood in the ditch teaches use no matter what you have some things just cant stop the accident from happening.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 12-10-2015, 02:16 PM   #17
Mr. Dan's Avatar
I agree. This information bordering on facts is making my head hurt/spin. Opinions and errors stated as fact are easier to dismiss.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 0; booked = 14
Old 12-10-2015, 02:18 PM   #18
Cowracer; good analysis but there is another factor involved which is oscillation. The slightest sway or compression of the trailer suspension can set off an oscillation that is reinforced by the wind. The amplitude will increase until the trailer tips.
SuwanneeDave is offline   Reply With Quote
Old 12-10-2015, 02:24 PM   #19
And do not forget to factor in inebriation into your amplitudinal oscillation equation. I have found that no matter what the dilemma, even if its an RV 90 degrees off kilter, inebriation is usually the proper action to take after the fact.
Mr Havercamp is offline   Reply With Quote
Old 12-10-2015, 02:25 PM   #20
acadianbob's Avatar
True, but if it can't turn one over standing still, moving down the road will make the problem worse. Imagine a wind coming at you at a 45 degree angle off of the front, now add your road speed. The road speed will add to the natural wind speed and put more side pressure on the trailer.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
