Old 10-11-2015, 12:11 PM   #11
Evereddie's Avatar
Originally Posted by Oakman View Post
This thread has become confusing to me. The vent on the outside of the trailer is for the range hood fan, not the microwave. Most RV microwaves Iíve seen are designed to vent into the trailer not out the hood vent.
As you can see in the picture the Microwave vents air out the top and into the trailer.
You are correct. If he was truly talking about the microwave fan, there is nothing to be done to it. It cannot be made to blow out the vent. It is not hooked to the vent. Only the range hood is hooked to the vent.
Evereddie is offline   Reply With Quote
Old 10-11-2015, 01:34 PM   #12
moodog's Avatar
Thanks that helped a lot. I was afraid to force it.
moodog is offline   Reply With Quote
Old 10-11-2015, 06:52 PM   #13
I don't know. I have a outside vent and no air comes out of the vent. When I turn on the range hood air comes out in camper. I have been putting it off dropping the microwave but I will drop it this week and see where the outside vent is at, the hole that goes outside.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 10-11-2015, 07:05 PM   #14
Evereddie's Avatar
Old Coot said it. The wires on the fan were probably hooked up backwards. Don't know your camper but you should be able to pull off a protective metal cover under your hood and switch the wires.
Old 10-11-2015, 07:39 PM   #15
It doesn't take that much to drop microwave. I don't mess with anything electric, I'm a danger to myself as well as others.
Old 10-11-2015, 09:44 PM   #16
SilhouettePenny's Avatar
I think you are confusing the microwave with the vent hood. Microwave should slide out from it's cabinet while the vent hood drops down after removing just 4 screws. Turn off shore power first then disconnect 12v battery. Drop the vent hood, reconnect the 12v battery and switch on the fan to determine which way the air is blowing. Then check the wall vent hole to determine if a blockage exists. I've seen fans installed backwards, cardboard blocking the vent hole in the wall and exterior wall flapper siliconed shut for unknown reasons. Good luck with your project.
2017 F350 Dually 6.7 Diesel
2014 Silhouette 299 RKDS
Nights Camped 2017 - 63
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 10-12-2015, 12:46 PM   #17
On my microwave you take two screws out from the top and the microwave will tilt down, then you take the microwave off the bracket. My microwave is not hooked up to 12volt power, just 110
Old 10-12-2015, 01:15 PM   #18
Left Coast
X2
Old 10-12-2015, 01:20 PM   #19
Hey wait a sec,did you OPEN the outside Flap Door?? Youroo!!
Old 10-12-2015, 01:50 PM   #20
Evereddie's Avatar
He did. Then said he has to turn the motor around because it's blowing backwards.
vent
