Old 11-10-2015, 04:44 PM   #61
Witch Doctor's Avatar
Originally Posted by bob caldwell View Post
Ok, gett'n a better idea of the lash-up. The slots just let you take up play, but because of the slots and empty spaces of these slots that the bolts don't take up, is where the problems stem from...so once the wedge is installed, the left over slot needs to be filled with weld, or a stud like OC suggested. Still wondering why Glenn had a problem
I'm not sure I'm positvie that I checked the torque. OC thinks it fell out after it was installed by the dealer. But I think the welds rusted as shown in the picture. When I came home from Goshen I hit that pot hole that broke my whole island over and broke all the screws holding it down. That could have broke the nut loose. Now I have cleaned mu truck bed atleast 50 x's and never saw that bolt laying in the bed. Rain water will get in that pin box there are 4 1/2 " holes above that area. Something rusted them. Did I check them all the time no just as the video said 150 lbs one time. They only tack in two places and there is a lot of stress put on them. I also could not move that box by hand at all, the truck had to do it. I like it being a little tighter then it come's with so much play easier to hook-up. So really I do not know, OC has a point as mentioned earlier that it was never set right. He's the smartest man that I know, that can work on anything, so your guess is as good as mine. If anyone says they check the torque before every trip I'll sell you a BRIDGE.....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 11-10-2015, 04:50 PM   #62
Left Coast
In the morn, I'll stop by the dealer here and get up and personal with one...
Old 11-10-2015, 05:04 PM   #63
Originally Posted by gljurczyk View Post
... But I think the welds rusted as shown in the picture. They only tack in two places and there is a lot of stress put on them...
Glenn, the rust happened after the nuts broke loose. It is common manufacturing practice to tack weld nuts to hold them until they are torqued. If the bolt is not torqued and comes loose, (which is what happened when your dealer didn't torque them) if you start pounding the bolt sideways, it will break the tack welded nuts loose which is what happened in your case. It is not a design flaw, it is dealer incompetence.
BTW, the weld itself can't rust where yours was until it is broken.
Old 11-10-2015, 05:07 PM   #64
Left Coast
So his trailer didn't come with that pin-box from factory? Wouldn't the only thing the dealer would do it set the wedge? Try'n to visualize where that bolt/nut came from
Old 11-10-2015, 05:42 PM   #65
It came from the factory with the Revolution. the dealer set the wedge and took out the lock bolts in the rear. When the dealer installed the custom wedge, he didn't torque the bolts in the wedge to the specified 150 lb/ft.
Old 11-10-2015, 05:54 PM   #66
OC I think you might be right, I'm the first to admit that. I'll take your scenario over anybody's. Something happened that never should have. It's a great pin box I couldn't be without it even with my Husky slider. That helped us once we broke it loose after 4 years of non use. I learned a lesson. I will try it now and then just to keep it loose. I think it is the best thing since P&J and for Bob POOP SALAD. Do you think that pin weights 150 lbs.? How would one person walk it off as they suggested yearly to do maintenance? Maybe that big BULL Youroo could do it but not me. Your the Man OCE and OCW is trying to catch up..... and he just sit there and FOUL..
Old 11-10-2015, 06:03 PM   #67
Left Coast
Just explore'n all avenues, sonny..
Old 11-10-2015, 07:06 PM   #68
leefl's Avatar
It's all about the 'trike'.....went with slider, which helped turns, but because this truck has an 8' box and the pin sits directly over rear end, I'm only using about 1/3 of it's ability. So that equals about 8"..... If I went with the Rev I'd pick-up alot. To give myself a little more room on turns, I can lower the platform the trike sits on on the pass. side of bed as that's the wide end.. I've also removed wheel and fender for more turning......state parks are the poops here.
If you have an 8ft truck bed, why do you need any slider or a revolution/sidewinder ?
Shouldn't you be able to turn fully with plenty of clearance between the corner/side of the trailer and the back of the cab ?
I only needed to unlock the revolution because of my 6'9" bed.
With the 22" offset of the revolution, I have over 9" clearance, so with an extra 15" of bed-length, I'd still have 2" clearance I guess (since (15+9)-22 = 2).
Ok ... I guess that's not a LOT, and it is assuming a similar king-ping relative to the front of the camper, and a similar camper width.
2015 Rockwood Signature UltraLite 8281WS
2016 Ford F-250 Lariat CrewCab, 4x4, 6.2L V8
leefl is offline   Reply With Quote
Old 11-10-2015, 07:09 PM   #69
B and B's Avatar
Do you want it? I don't know yet if they want it shipped back, if not I'll sell it cheap to you. Just pay transport fee's, can give it to you at the rally in May. Unless you want it shipped? If so then we can see if I can do it...
It wont fit OCW it is too narrow, will need a spacer fabbed at OCE shop maybe..
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 11-10-2015, 07:11 PM   #70
B and B's Avatar
I'm into salvaged parts!! If they don't want it back and it can be loosned up , the rally would be OK. When I get back home and on desk top, I need to check the whole hitch deal out....pin-box and bed unit.
I tore mine down prior to getting a replacement. I also lubbed the shaft with lithium grease. The new pin box has grease on it. The 16k Revolution i saw on the new Rockwood was smooth as silk.
