07-19-2015, 08:11 PM
Refrigerator problems
We are going camping in a couple days so we thought we would get the fridge cooled down ahead of time using the propane. We tried several times to get it turned on but it would not work. We lit the stove thinking there might be air in the lines. Stove worked fine, tried fridge again and it still wouldn't work. We camped a month ago and it worked great. Any suggestions?
2011 MicroLite 23LB
2012 Ram 1500 Crew Cab
07-19-2015, 09:04 PM
Using electric or gas, always on level grounds, does wonders for some.
07-19-2015, 09:06 PM
what model have you got
haven a blast
07-19-2015, 09:56 PM
The camper is MicroLite 23lb, Dometic fridge and camper is completely level so that's not the problem. Couldn't get it to work using the propane. Didn't try electric.
2011 MicroLite 23LB
07-20-2015, 08:57 AM
Did you bleed the air out of the gas line? I always had to do this on my other two 5er's to get the fridge to work on propane.
What I did was to turn on the stove and wait until I could light the burns once they were lit, I would than turn on the fridge with propane. Another thing is make sure there are no spiders or webs in the gas igniter and tube for the fridge.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
07-20-2015, 09:16 AM
There is a chimney hi temp reset that may have tripped. Push the button and see what happens.
07-20-2015, 09:19 AM
Believe it or not. I once had the same symptoms and was told to try to reset the fridge controller. Couldn't figure out how to do that so I disconnected the battery for a few minutes, re-connected and all was well. Shutting the disconnect didn't work. Not saying this will fix you but after checking all the above and that doesn't do it, you might try the battery thing.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
07-20-2015, 09:33 AM
You can also remove the fridge fuse for a few minutes, Probably easier than disconnecting the battery.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
07-20-2015, 09:47 AM
A bug nest in the flue will allow AC operation; but an over rich mixture preventing propane ignition.
Do you smell propane outside when you are trying to cool on propane?
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
07-20-2015, 10:15 AM
Make sure that you have a battery that is fully charged. The ignition is 12V when you're running the fridge on propane.
07-21-2015, 09:58 AM
Well, we found out what the fridge problem was and it was an easy fix. The battery was not charged enough. We hooked it up to the truck, turned the fridge on and it came on right away. Thanks to everyone for your help!
One other question just for future reference. Is the battery needed just to light the fridge the first time when using propane or if the fridge is running on propane, does the battery have to be fully charged to keep it running?
2011 MicroLite 23LB
07-21-2015, 10:13 AM
Minimum 12 volts or about 60% discharged.
When the "GOOD" light goes out; you need to be recharging the battery.
07-21-2015, 01:29 PM
If you expect the fridge temp to be maintained, then yes, the battery is necessary.
