Old 06-14-2011, 05:13 PM   #11
DF5.4's Avatar
Originally Posted by mtnguy View Post
Doug, you beat me posting by just 1 minute.
I typed a shorter answer.
Doug
2011 Prime Time Tracer 3000BHS
2007 Ford Expedition
Reese Dual Cam HP Hitch
Nights Camped 2015-5 in TT
DF5.4 is offline   Reply With Quote
Old 06-14-2011, 05:22 PM   #12
Herk7769's Avatar
Originally Posted by HemiCab View Post
Lou what do you mean by "too much"? I have it planned to start mine early for a trip and that statement made me wonder. One full turn of both tanks (2 - 20 lb tanks).
Oh, I meant the fridge DOOR! Not the bottles! (OH and I should have read all the posts before posting this -
Always open the bottles FULLY. I always open BOTH bottles (especially if you are on shore power!) just in case one bottles runs out early. Always have propane available if food is in the fridge! If the campground loses power the propane will keep your food safe till power is restored and it will aurtomatically go back to AC when power comes on.
HAM CALLSIGN - KC3FFW
Old 06-14-2011, 05:26 PM   #13
okdrifter's Avatar
Once the gas starts do you still need the battery?
Doug and Carmin
2010 Wildcat 31TS
2008 F-250 King Ranch
okdrifter is offline   Reply With Quote
Old 06-14-2011, 05:29 PM   #14
Herk7769's Avatar
Yep! Without DC available the fridge will not work on AC or Gas.
Old 06-14-2011, 05:32 PM   #15
okdrifter's Avatar
Thanks plan B needs to be put in to effect.
Doug and Carmin
2010 Wildcat 31TS
Old 06-14-2011, 06:29 PM   #16
ken0042's Avatar
^^ I was just going to ask that. How much DC power does the fridge use when running on propane? (Assuming you could turn everything else off.)
Wolf Pup T16P owner
"The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine." - Abraham Lincoln
ken0042 is offline   Reply With Quote
Old 06-14-2011, 06:39 PM   #17
caper's Avatar
The condition of the battery will determine how long the fridge will stay on propane. If the battery is not fully charged it might be dead before Thursday. The battery should also be charged before moving the TT. The breakaway switch for the brakes will not work with a dead battery.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 06-14-2011, 07:46 PM   #18
DF5.4's Avatar
If your fridge has a climate control on it, turn it off. I've seen it as a switch under the control panel in the freezer door jam. It is an electric heating element in the door seal that keeps moisture from building up on the seals. It will kill a battery fast.
Doug
Old 06-14-2011, 10:53 PM   #19
Herk7769's Avatar
On 12VDC and Propane my DM2652 uses 1.2 amps when actually cooling (almost none when not). So say without opening the door it turns on for 10 minutes every hour to keep the frozen stuff frozen it will average 1/6th of 1.2 amps every hour or 0.2 amps average.
If the fridge and the propane leak detector (0.2 amps constantly) are the only things using power and you start with a fully charged 75 amp hour battery, then your battery will last 75 divided by 0.4 amps or 187 hours.
7.8 days.
This is NOT what you will get. Just what I think you might get under optimum conditions. If the camper is in direct sun on the side of the camper with the fridge you will get less. Maybe much less if its hot out and it runs more often.
G. CLIMATE CONTROL
During the summer months of high temperatures and humidity, the metal frame between the freezer and fresh food compartments may have water droplets forming. The number
of water droplets will increase if the vehicle isn't air conditioned during these months.
This refrigerator comes standard with a 12 volt (DC) climate control that will evaporate the water droplets when they form.To have the climate control on, you position the switch ("C",
Figure 10) located beneath the top decorative strip that houses the control panel to ON. The climate control can be left on continuously or only used when temperatures require
it.
! CAUTION
THE CLIMATE CONTROL WILL DRAW 12 VOLT DC POWER CONTINUOUSLY WHEN IN THE "ON" POSITION. IT SHOULD BE TURNED "OFF" WHEN A CHARGING
SOURCE IS NOT AVAILABLE. IT WILL QUICKLY DRAIN THE CHARGE FROM A BATTERY.
Old 06-15-2011, 12:25 AM   #20
Terier's Avatar
  • Isn't there power to the breakaway switch when it plugged into the truck and the engine is running?
  • On another note - it was suggested to me not to have both propang tanks open at the same time so that you will have to switch over when the first tank is empty. By doing it that way you will know when you are actually using the second tank. Of course there are pros & cons for either way so it's a matter of choice.
