Old 05-22-2011, 08:31 AM   #1
remove antifreeze from water system
We are getting ready to use our new Rockwood for the first time and need to de-winterize the water system. Any tips or tricks we should know?
hamrick44 is offline   Reply With Quote
Old 05-22-2011, 08:44 AM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
to the forums. If you kept the jugs the antifreeze came it you can recover some of it by opening the low point drains. Otherwise hook up a hose and start rinsing it out. I haven't used antifreeze in quite a while but when rinsing I usually opened my grey tank drain and just allowed it to run out. It becomes so diluted it doesn't harm any thing. Don't forget to change the position of the water heater by-pass once you've completed your rinsing.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
antifreeze
