Originally Posted by 007matman
I don't think you can nail into steel and expect it to stay. My guess is you have screws in there too.
You can nail into steel and believe me, they will stay.
Not just with an ordinary nail but a tempered nail that is driven into place using an explosive charge. The gun that drives them uses a small blank cartridge that is just like a miniature .22 caliber cartridge.
The tempered steel nail enters the steel so fast it stretches the steel to make the hole and the steel than shrinks back around the nail which can have little serrations on it to help grip.
In construction it's a neat tool to fasten things to girders and heavy sheet steel you don't expect to remove. For a belly cover on a trailer its just used to benefit the factory. Using TEK screws would also get the job done but make it easier for later service (electrical, reinforce water tank support, etc).
After making my initial post I crawled under the trailer and tried to remove a couple with a sturdy vise grip. I found that if you get a good grip on the head a couple of twists will free it up. Took me 15 minutes to remove two.
Found that the ones on mine have a 1/4" hex head on them. Tomorrow I'm running my super long air line out and hitting them with my 1/4 drive impact wrench (what a neat tool for all kinds of projects). If they won't come out while turning I'll just help them along with my flat prybar under the washer. I think I'll just drop one side and let it rest on top of the axles so I can run the wires I want to. I'll also address any shortcomings in the factory install. Working with one side down looks a lot easier when it comes time to reinstall.
I'll be using Tek screws. Even if the hole size isn't quite right it can drill it out with it's own drill tip.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
