Old 09-12-2016, 09:33 AM   #1
Replace TV Antenna?
I have what I believe is a CA 1500 omnidirectional tv antenna that just doesn't pick up signals very well. Any suggestions for a replacement that won't require major mods to the roof?
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2016: 38 nights camped
Teamfour is offline   Reply With Quote
Old 09-12-2016, 09:45 AM   #2
RSchleder's Avatar
I'm not sure of the exact procedure to replace your antenna. However, the only antenna I would use as a replacement is the crank-up Winegard antenna with the Wingman accessory attached to it.
Days camping (2016)----181 days
Days camping (2017) --- 21 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
12 different RV's
RSchleder is offline   Reply With Quote
Old 09-12-2016, 10:09 AM   #3
Thanks. I would like to get a crank-up antenna, but the location of the current one doesn't allow for a crank on the interior.
Lee and Anne
Old 09-12-2016, 10:27 AM   #4
Ford Idaho's Avatar
Antenna booster switch on?
If it is then Jack is the way to go if you need a solid mount antenna.
https://www.google.com/aclk?sa=L&ai=...Q0QwIRg&adurl=
Ford Idaho is online now   Reply With Quote
Old 09-12-2016, 12:17 PM   #5
Yep, booster is on. I even pulled the booster assembly to check that all connections were tight. We have gotten a great signal when camped near large cities so I know the system works. Just looking for an antenna that may pull in weaker signals.
Lee and Anne
Old 09-12-2016, 01:51 PM   #6
I may not need a new antenna after all. Looks like the area we were camping in may just have poor proximity to strong signals. Here is a graphic of the stations in the area. Any stations in the red or grey are considered marginal for anything other than the strongest antenna.
Lee and Anne
Old 09-12-2016, 01:59 PM   #7
Flybob's Avatar
That antenna is junk. Attached is info. I recommend replacing with a Jack antenna, but it will require some modifications as the OEM antenna is mounted using a small hole in the roof( for coax) and no hole in ceiling as it can not be rotated. I use a temporary external cheap $40 antenna when I need tv and it is 2-3 times better. Any antenna that does not publish gain spec is suspicious.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 09-12-2016, 02:10 PM   #8
Thanks Bob! I am leaning towards a cheap external antenna as you suggest. Might even make one myself.
Lee and Anne
Old 09-12-2016, 02:27 PM   #9
Georgia Frog Rally 2017
aceinspp's Avatar
X 2 Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days booked for 2016--60 missed by 2
Days camped in 2016 58
Days booked so far in 2017 37
aceinspp is online now   Reply With Quote
antenna
