Old 04-28-2018, 09:37 AM   #1
Replacement Fenders?
Obviously fender washers won’t help. Is the factory the only source for new fenders?Click image for larger version
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
Teamfour is offline   Reply With Quote
Old 04-28-2018, 09:40 AM   #2
john5646's Avatar
Just a thought. Remove fender, apply fiberglass resin purchased at a local auto store or possibly even JB Weld a two party proxy mix. And apply it to the backside.
john5646 is offline   Reply With Quote
Old 04-28-2018, 09:41 AM   #3
Mainframe's Avatar
I would order those from the factory no problem, I ordered things and they were quite accommodating and reasonably priced.
2016 Shamrock 23WS
2018 F150 Ecoboost
Mainframe is offline   Reply With Quote
Old 04-28-2018, 10:31 AM   #4
Lee, Go to icondirect.com. They advertise in Trailer Life magazine and carry fender skirts, brand specific.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 02-08-2019, 09:55 PM   #6
Brother Les's Avatar
Originally Posted by Teamfour View Post
Obviously fender washers won’t help. Is the factory the only source for new fenders?Attachment 169811
What did you do about your fender skirts, I have the same problem on my front slide. The skirt is on the slide is 3/4 of the skirt and the other 1/4 is attached to the non moveable siding. The 3/4 skirt flops around to much going down the road because of a lack of support to keep it from moving back and forth.
I have looked to order the skirt, but can not fit this 3/4 to 1/4 match up of the dual wheel skirt.
Brother Les
Old 02-09-2019, 08:12 AM   #7
Hi,
I removed both fenders, reinforced all my cracks with JB Weld (to include embedding shaped wire in the puddle) and then used stainless washers on the outside to spread the loads in the future.
FWIW.
Rich Phillips
Rich Phillips
2019 K-2500 Duramax Crew Cab
2014 Silverback 33RL
richp is offline   Reply With Quote
replacement
