Old 05-22-2015, 12:36 PM   #1
indybp57's Avatar
Reversed polarity - what now?
Just wondering what those of you who have discovered reverse polarity at your campsite have done about it? Moved to another site? What if the whole section of sites are that way? Report it? Is the campground going to send an electrician out to fix it? Just wondering, short of going home what would be your options?
2013 Roo 183
Miles Driven/Nights Camped:
2012:1042/13 2013:2772/27
2014:2259/30 2015:1644/20
2016:1278/23 2017:2183/22
indybp57 is offline   Reply With Quote
Old 05-22-2015, 12:39 PM   #2
indybp57's Avatar
And another thought, ground and neutral are normally bonded somewhere within the campground electrical system. Does reverse polarity mean that hot and ground are mistakenly bonded, or just that the outlet wires are reversed?
2013 Roo 183
Old 05-22-2015, 12:43 PM   #3
wmtire's Avatar
Never had that happen. I would think it would occur only if the campground had had very recent work done either to the entire wiring or an individual pedestal.
I guess it would depend on the campground and timing as well as their owner/employee expertise, as to if they could repair it onsite or have to call in outside help.
If moving to a proper wired site is not an option, nor can they fix the problem ASAP.... I would think you would need to get a refund and find accommodations elsewhere........ unless you want to camp there without electrical hookups.
Are these truly hypothetical questions or have happened to you?
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 05-22-2015, 12:48 PM   #4
hkreck's Avatar
I ran into this situation a couple of years ago, went into a camp ground in Texas. the first site show a RP so they moved me to another site, same thing then another and another. I finally asked if I could have my money back which they did and I moved on down the road to another camp ground. The maintenance man stated all these other RV's aren't having this problem maybe it's your surge protector? But it's worked fine every since. I did have one other time where it showed a RP turned out the plug wasn't in tight enough for a good ground.
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 05-22-2015, 12:57 PM   #5
This is where you want to have a plug-in tester. Then he can't claim it's your RV.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 05-22-2015, 01:18 PM   #6
hkreck's Avatar
I was using a Portable Surge Guard at the time which was showing the RP.
Henry & Tena
2013 Solera 24S
The Great Escape
Old 05-22-2015, 01:24 PM   #7
TURBS's Avatar
Others weren't having an issue because they were none the wiser
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "6 nights"
Old 05-22-2015, 01:55 PM   #8
MilCop4523's Avatar
TURBS
exactly. in my other post about surge protection a few yrs ago the campground happened to blame the power company for frying a street full of trailers in one evening... mine included.
knowing the chief electrical inspector i made a couple calls and emails appear with images of the dig...
when he got on site the electricians were replacing the panels without a permit... and basically told him (not knowing who he is) to buggar off...
he did and came back with his business card and a stop work order and a notification for the site to provide all electrical permits and work done in the past 10 yrs or that they would have to shut the site down and have it all dug up and replaced. burnt....
09 Sundance 31.5 XLT Bunkhouse
17 Greywolf 22rr Toy Hauler
and
The new toy hauler - 2016 Ford F150 Supercrew XTR ECOBOOST.
MilCop4523 is offline   Reply With Quote
Old 05-22-2015, 02:10 PM   #9
TURBS
Yep. My understanding is that, with a reverse polarity situation, you would still have electricity going to an outlet or appliance even if the breaker tripped because it would be tripping on the return path rather than the send path. Sound right?
Old 05-23-2015, 06:45 AM   #10
I recently experienced this same thing. It was at Lake Kissimmee state park. I called the Rangers office and a ranger/electrician was there in 2 minutes to rectify the problem. I had a hike scheduled so I didn't stay around to see what the fix was
2015 274 RK LIMITED <'{{{{><
captainperry is offline   Reply With Quote
